Sponsored by: Real Truck
2012 f450 steering? Issue
Old Mar 30, 2022 | 04:06 PM
Sentrand's Avatar
Sentrand
Anyone have any idea why the truck is doing this? Truck has 120000 miles on it.
dealer recently replaced ball joint. (it drove like this before ball joint being replaced)
And a dampener was replaced today.
Old Mar 30, 2022 | 04:08 PM
2006lariat's Avatar
2006lariat
What is it doing?
Old Mar 30, 2022 | 04:09 PM
Sentrand's Avatar
Sentrand
I thought I had a video attached showing the steering wheel move.
Old Mar 30, 2022 | 05:12 PM
Sentrand's Avatar
Sentrand
Originally Posted by 2006lariat
What is it doing?
Old Mar 30, 2022 | 07:20 PM
leadmic's Avatar
leadmic
You have something very loose. You need to have someone move the steering wheel back and forth while you get under it and see where the play is.
Old Mar 31, 2022 | 07:44 AM
speakerfritz's Avatar
speakerfritz
looks like bump steer to me.
is the truck lifted? if it is, it has the wrong size track bar bracket re-location
oEM dampers are pretty weak.....my truck dud that after my lift with the oem damp until I replace the oem damper with a fox 2.0 damper.
but to answer your question, the bump steer is cuased by linkages that are moving slightly vertical when they were designed to move horizontal. once the geometry changes thru modifications, worn front springs, etc, what was a pure horizontal motion becomes slightly vertical. steering wheel moves in response.
Old Apr 1, 2022 | 11:06 PM
jetjockey99's Avatar
jetjockey99
If your F450 is a 4X4 I would check the u-joints at the steering knuckle. They can seize and cause that exact symptom.
bfediuk
Jul 20, 2019 10:00 PM
tombob
Escape & Escape Hybrid
Mar 6, 2014 07:44 AM
muffin1
Jun 24, 2013 03:49 PM
uberkarldrei
Sep 11, 2007 01:09 PM
