Sponsored by: Real Truck
DRW to SRW conversion
Old Mar 30, 2022 | 09:45 AM
Sparky04SD's Avatar
Sparky04SD
My son owns a 2002 F350 DRW 4x4 7.3 ZF6 truck and uses it to pull a gooseneck stock trailer on his farm. It has always been an issue during winter snows getting around. The 8' pick up box is in need of replacement and he wants to put a flatbed on the truck but would prefer to convert the truck to SRW and use the narrower bed. We know the DRW rear axle is different from a true SRW but can wheels be found to keep from having to replace it? Regarding the front axle, can the dually adapters be removed and SRW wheels be bolted on then?
Old Apr 8, 2022 | 05:44 PM
Sparky04SD's Avatar
Sparky04SD
Removed the dually adapters and bolted on stock Ford 16" steel SRW style wheels. The bolts used for attaching the adapters are not long enough to bolt on aluminum wheels but steel wheels are fine. You would have to install SRW hubs to have longer lug bolts for aluminum wheels. Now working on wheels for the back axle. Stock Ford 16" steel bolt on but will need spacers for correct location regarding being inline with front wheels.
urbex
Apr 11, 2018 04:23 PM
Truck Guy99
21
Jun 22, 2014 02:19 AM
six6six
Aug 21, 2011 04:39 PM
Brown Falcon
Oct 19, 2008 05:35 PM
