Replace halogen with LED?
Old Mar 29, 2022 | 09:38 PM
Garbageman 134's Avatar
Garbageman 134
I didn't want to spend 1700.00 on factory led's so I went down the rabbit hole of aftermarket led's. This vendor appears to have a good reputation and allegedly the led's are engineered to orient the light beam correctly instead of just throwing light everywhere.
DDM Tuning Saber 55W ProX Accu/V2 LED Kit, 12500LM, 6000K, Pair,--FBA (H13 Hi/Lo)
$178.00 Has anyone had success w/ aftermarket?
Old Mar 29, 2022 | 09:42 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You should have bought the factory option.
Old Mar 29, 2022 | 09:44 PM
Gomerpyle's Avatar
Gomerpyle
Personally, I spent $80 for LED bulbs & "throw light everywhere". Works for me.
Old Mar 29, 2022 | 10:00 PM
jollyrogr's Avatar
jollyrogr
I went with Hikari ultra's and they work good. Very bright and I never get flashed. With the $3000 I saved, I can fill my tank a couple times and buy a few loaves of bread to feed the fam.
Old Mar 30, 2022 | 07:08 PM
Bowtienomore's Avatar
Bowtienomore
Headlights only
I went with Auxito... I did an entire vehicle kit and cannot recommend it or the company as I had to customize their bulb bases and order different reverse bulbs from Alla Lighting. I loathe giving Auxito any more business...
The LED headlight bulbs are a brighter, whiter version of the stock ones. The beam pattern is good right out of the box. I didn't need to adjust or re-aim. No objections from oncoming vehicles either. If I had it to do over again, I would go with Alla Lighting or F150LED$$$. All of F150's stuff is supposed to be Cree chips and they have an excellent reputation.
Old Mar 30, 2022 | 07:11 PM
Garbageman 134
The LED headlight bulbs are a brighter, whiter version of the stock ones. The beam pattern is good right out of the box. I didn't need to adjust or re-aim. No objects from oncoming vehicles either. If I had it to do over again, I would go with Alla Lighting or F150LED$$$. All of F150's stuff is supposed to be Cree chips and they have an excellent reputation.
Just today I installed the light bar on my front bumper that is sold by f150leds. Supposedly it has the Crete LEDs in it. It is bright but the supplied mounting brackets are way too small and I will probably have to have some larger ones fabricated to give me more aiming adjustability
Old Mar 30, 2022 | 09:03 PM
RedNNBlue's Avatar
RedNNBlue
Blinding other drivers is not cool. In some states, its not legal or would not pass a state safety inspection.
Old Mar 30, 2022 | 09:05 PM
RedNNBlue's Avatar
RedNNBlue
I'm not familiar with the brand you mentioned. I do believe that generally speaking, you get what you pay for. I am quite pleased with the lights I have on my '02 from Headlight Revolution.
Old Mar 30, 2022 | 11:58 PM
aklim's Avatar
aklim
Hikari here. Seem to be decent and only got flashed when I left the brights on after testing.
Old Mar 31, 2022 | 12:58 AM
honda250xtitan's Avatar
honda250xtitan
DDM is garbage. they have a reputation.
Old Mar 31, 2022 | 04:35 AM
gaj0137's Avatar
gaj0137
I have BEAMTECH H13 LED Bulbs I got from Amazon in my F-250 for over a year with no complaints, huge improvement over the stock halogens and have the same beam pattern as OEM bulbs.
Old Mar 31, 2022 | 06:35 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
2nd the Beamtech just put them in my F350 dump truck works great and easy install from engine side have the 7.3L
Old Mar 31, 2022 | 06:53 AM
Pugga's Avatar
Pugga
Google DDM Tuning, their reputation is not great. Other forums have had issues with them in the past.
I went with Headlight Revolution's LED V4 kit and am happy. Apparently, I throw light all over the place... but I don't get flashed by other drivers and I pass inspection every year.
Old Mar 31, 2022 | 07:10 AM
jimzpsd's Avatar
jimzpsd
I also have the Beam Tech's.......five years old and no issue. $65 for all four.
Old Mar 31, 2022 | 01:33 PM
Miles Mac's Avatar
Miles Mac
This is what I have in mine - Great quality
https://www.f150leds.com/collections...-headlight-kit
