TFI Wiring Diagram
#31
#32
#33
On your duraspark harness you may have a pigtail coming off the coil and ground wire from the dist according to this diagram. Even if you have this, I think your main problem is the wire from the dash was cut during the conversion and is wrapped up in your old harness under the hood somewhere. If you can find that wire, you could easily hook it to the coil negative.
#34
I ran a quick test wire from the coil negative to the plug with the light blue wire that I mentioned above and the tach started working. Maybe I will steal the female plug off the old TFI wiring harness to make it a nice clean looking connection instead of cutting the truck wires up. Honestly the wire colors aren't really matching up with the wiring diagrams but if it works I will just go with it ha. The rest of the wiring colors check out, just not the tach.
#35
https://www.ford-trucks.com/forums/1...l#post14455069
Your truck, is a V8, and thus needs a green and black on the engine side of the plug. 2 wires on each side of the plug. The extra black wire on the engine side is a ground which makes the tach read correctly for a V8.
Jim
#36
See this post for a photo. Post 5
Jim
Jim
#37
Okay I see what happened now. The duraspark harness I found was missing the 4 pin male connector that goes to ignition module, which I replaced. But I didn't realize there should also be a 2 pin female connector there as well (for tach). So I should be okay if I add in a ground wire and wire to negative side of coil correct?
#38
More info on using tfi distributor with old school carb
Hi, I have a new 2100 old school carb for my 85 Bronco II 2.8, and all of the duraspark conversion parts - except distributor.
I'm game to try the locked TFI approach, can you be more specific how I hook up the existing TFI system to lock the timing? Do i leave module and coil all wired as factory, and manually set timing to 25 btdc?
Thank you, Steve
Thank you, Steve
#39
Thank you, Steve
Thank you, Steve
Have you pulled all the computer wiring out? I would to get it out of the way. You can find the computer behind the pass side kick panel in the interior. Pull it out, and unplug the very large wiring plug. Cut the few wires going to a relay off and tape them. The rest of the remaining wires should go though a large rubber grommet in the firewall. Push this grommet out of the firewall, and then push the large plug with all it's wiring through the large hole and into the engine compartment.
Take the large plug and start gently tugging on it. Anything hooked to it, unplug it and take it out. You will need nothing hooked to this harness.
Once you get the harness out, find the wide plug that went to the original TFI distributor Follow this group of distributor wires as far as you can and cut them. Then unwind them so they are loose going to the old TFI distributor. Cut the top wires coming out of the plug about a inch long, just in case some day you might want to use them for something. Keep the bottom 3 wires long. Wire them up like the diagram below.
I ran these 3 wires in a piece of loom, and ran them over to the driver's side fender. I used the original TFI coil. Over on the driver's side fender in all those wiring plugs you should find a white/lightblue stripe wire. This is your ignition hot. It needs to be tied to the TFI coil + and also the 3rd wire up on the TFI distributor. If you do not still have the TFI plug, you can hunt it down in the harness you pulled out.
The 2nd wire up on the dist goes to the other terminal on the TFI coil.
Originally the TFI coil had a heavy black ground wire bolted to the coil base, and then running over and bolted to the engine block. You need this since the driver's side inner fender is plastic. I used this ground wire for the lower most ground wire on the TFI distributor. That's all you need.
You will have to experiment with the timing. You want it as advanced as possible, but you still want the engine to crank over when it's hot.
#40
How kind of you to respond so quickly and completely. I won't need the computer harness that you have described under any of these scenarios, is that correct? A. Fixed timing with existing distributor and coil; B. Duraspark distributor and module; C. Points-type distributor and 12v coil if I can get one for the 2.8.
Thanks again
Thanks again
#41
Thanks again
Thanks again
Wesley Foy
10-25-2021 05:08 PM
