Clutch Issue
Old Mar 28, 2022 | 11:33 AM
Batgeek's Avatar
Batgeek
Clutch Issue
My dad passed away a little over a year ago. I inherited his 1992 F150 Custom 4.9L 5-speed. I just picked it up to find it had a multitude of issues. One of them is the clutch pedal goes to the floor and stays there. There is no resistance in the pedal, no hydraulic pressure. I shifted it into gear and nothing. I checked the linkage where it connects to the master cylinder and it looks fine. I don't see any leaks anywhere. There does appear to be a lot of clutch material when I looked through the inspection hole. No leaks at the slave cylinder. What are your thoughts, new master cylinder, slave cylinder, clutch, or all of the above.
Old Mar 28, 2022 | 11:40 AM
SFaulken's Avatar
SFaulken
Is there fluid in the reservoir on the Clutch Master Cylinder? I don't see where you say yes, no, or otherwise. If it's a truck that sat, it is entirely possible that it's gone dry. And sadly, if a fill and rebleed doesn't bring it back to life, you're probably dropping the transmission, and might as well plan on doing a clutch anyway.
Old Mar 28, 2022 | 03:04 PM
Batgeek's Avatar
Batgeek
Sorry, it was full.
dpty22
May 30, 2019 06:49 AM
Rexor
Apr 5, 2017 12:14 PM
Cryshalsing
Jan 15, 2017 04:44 PM
Ford Truck Racer
Aug 27, 2005 09:29 PM
cojo81
Apr 25, 2005 06:37 PM
