Swap pinion flanges?
Old Mar 24, 2022 | 06:02 PM
Bsick1985's Avatar
Bsick1985
Trailering
Can I swap pinion flanges from 2 2002 F350 7.3 with 3.73 gears one is a cclb. One is a regular cab there different companion yolks Long story short my crew cab chewed the bearings in the rear end and Ford wants $850 for the parts so I want to swap the rear ends but the only difference I see is the way the differential hooks to drive shaft. Can I just pull pinion nut and flange and swap them with new crush sleeve and setting preload of course.? Please help
Old Mar 24, 2022 | 06:25 PM
z31freakify's Avatar
z31freakify
Yes it will fit, no need to preload but if you know how do it, a good 1/2 air impact with good air pressure is adequate, along with marking the nut and pinion before removal so it can end up in the same place.
Old Mar 24, 2022 | 07:13 PM
Bsick1985's Avatar
Bsick1985
Trailering
Thank you good sir
I appreciate it and you're sure I don't have to do anything special
Old Mar 24, 2022 | 07:32 PM
udsuth78's Avatar
udsuth78
What's different if you don't mind, and what's the donor from?
Old Mar 24, 2022 | 08:44 PM
z31freakify
Nothing special I have replaced a few pinion seals using this technique no problem.
Usually the impact will get the nut right at the marks or close to the marks, you can do the rest by hand. Just don't over tighten it because that where the crush sleeve will get effed up.
Old Mar 25, 2022 | 09:52 AM
Bsick1985's Avatar
Bsick1985
Trailering
The yolks are different
[ QUOTE=udsuth78;20340822]What's different if you don't mind, and what's the donor from?[/QUOTE]
The yolks are different one as u joint caps with bolts the other has a flange with bolts They both are the same year and are f350s one is cclb one is reg cab long bed
Old Mar 25, 2022 | 10:39 AM
timmyboy76's Avatar
timmyboy76
Any pics bud?
I swapped my 99 xtra cab with my cclb bc I had 4.10s installed in the 99 years ago. Swapped axles 3yrs ago and it was plug n play
Old Mar 25, 2022 | 11:47 AM
Bsick1985's Avatar
Bsick1985
Trailering
Pics
This is the donor truck
Tectron1
Dec 18, 2014 08:45 PM
jjurva!
Dec 15, 2012 07:39 PM
RideDiesel88
Aug 19, 2012 02:36 PM
highoctane74
Dec 15, 2010 08:05 AM
