Radiator help please!
So if you had 135 140 135 140 145 150 I dont think I would worry but thats me
Dave ----
My thinking was no use putting the new radiator in if there is a head gasket leak .... I don't want to over pressure the new rad.
Funny, #6 was loose and I know I put them all in with a torque wrench (being over cautious since #6 was stuck when I got the engine).
I cleaned up all the seats with a round wire brush.
Got my new compression tester out.
Just did a quick test ... only turned over a few times on each cylinder.
Got about 135 to 150 on all six.
It had just started raining and I am working outside in VT till I get the new shop built.
I will do the test again tomorrow when it is dry and write down the #'s
I can't seem to find a # ... one book says with %10 of high to low ... another says within %25
So .... what should the compression be ?
Honestly I am surprised it is this high .... an 86 engine with at least 200K on it (had to replace the original one last year ... 250K and a rod bearing went).
Also, with this much compression, is it safe to assume I don't have a head gasket leak?
Thanks .... Mike
PS ... the #6 plug was not only loose but the seating area on the plug is full of carbon baked on so it was definitely loose for a while.
Thanks .... Mike
I suspect the radiator had a flaw that caused it to let go. Even if the cap was bad and didn't vent, I'd expect a hose to burst or let loose first. Good idea to replace the cap as a precaution, as you were thinking.
As Dave mentioned, a compression test won't always catch a minor head gasket leak. Those numbers look fine, by the way. For peace of mind, you can run a combustion leak check of the cooling system. This is the doohickey that looks like a turkey baster with some special test fluid inside. You run the engine for a few minutes and then draw a sample of the air at the top of the radiator. The test fluid changes color in the presence of combustion gas, indicating a bad head gasket leaking exhaust into the cooling system.
