Post injector o ring replacement
Old Mar 24, 2022 | 12:06 PM
Hammr412's Avatar
Hammr412
The truck takes a minute to prime when trying to start after new injector o rings. It has oil and it sounds like it's struggling to idle but it will hold rpm. Only thing I can think of is when I drained the HPOP rails and air allowed the oil to clear the cylinders. Is there a built up pressure somewhere that I didn't release?
Old Mar 24, 2022 | 02:49 PM
farmert's Avatar
farmert
Sounds like you still have air in the oil rails. After injector o ring replacement, it takes a while to clear the air from the oil rails. This will make the truck to crank longer before firing off. Once started, take the truck for a good run. It may take 50 miles or so to get all the air out of the oil rails.
Old Mar 24, 2022 | 08:26 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
You need 100 miles of spirited driving.
Old Mar 25, 2022 | 05:38 AM
FinnishStroker's Avatar
FinnishStroker
Beat the heck out of it.
Did you swap internal o-rings too?
(I ask this in every injector oring thread)
Dopp Creek
Feb 29, 2020 10:27 PM
RVHauler32
Mar 2, 2019 12:42 PM
4x4countryboy
19
Apr 22, 2012 07:10 PM
MONAVIERONJON
Feb 18, 2010 11:08 PM
jrlowscot
Nov 14, 2006 10:08 AM
