needing pistons
Old Nov 7, 2003 | 09:56 AM
824x4ride's Avatar
824x4ride
Question needing pistons
does anyone know were i can get a set of flat top 351m pistons?...iam having no luck finding some...thanks in advance
Old Nov 10, 2003 | 09:07 PM
HawkeyeF100's Avatar
HawkeyeF100
How close are Sterling/Federal Mogul part # STL-451P30 (30 over) to your needs?
3.50 stroke , 6.580 rods , .088 inch dish
About $9 each.
Old Nov 10, 2003 | 11:59 PM
824x4ride's Avatar
824x4ride
havent checked them out but i will i apreciate the info hawk
Old Nov 11, 2003 | 10:37 AM
bubbaf250's Avatar
bubbaf250
The only mass-produced 351M flat-top piston I've ever seen is the SpeedPro (TRW) #L2466F, and it is available in 0.030" oversize only.
Advertised CR: 10.83:1 (58.6cc heads), 10.43:1 (63cc heads), 9.84:1 (67cc heads), 8.96:1 (76.2cc heads), 8.78:1 (78.4cc heads).
Old Nov 11, 2003 | 12:35 PM
HawkeyeF100
Summit no longer carries the TWR L2466F.
Maybe JEGS ???
Keep your stick on the ice
Old Nov 11, 2003 | 01:47 PM
824x4ride's Avatar
824x4ride
does anyone know of a web site for TRW pistons??
Old Nov 11, 2003 | 02:12 PM
HawkeyeF100
I think TRW Pistons are made by Speed Pro.
They must be owned yet another company. I can't find anything on the web about a manufacturers site and none of the part sellers have a link to Speed Pro or TRW.
I'll do a bit more digging and see if I can find who owns them , but I don't think they will have anything usefull about pistons on the net.
Summit has the best list so far.
Old Nov 11, 2003 | 02:52 PM
Brian S's Avatar
Brian S
PISTONS, RINGS AND WRISTPINS
AE Clevite Engine Parts
325 E. Eisenhower Pkwy. Ste. 202
Ann Arbor, MI 48108
313 - 663 - 6400
Fax 313 - 663 - 6400
Accralite Pistons
Spon Lane S.
Smethwick,
West Midlands, B66 1QJ, U.K.
0121 - 525 - 6450
Fax 0121 - 553 - 5951
Arias Forged Pistons
13420 S. Normandie Ave.
Gardena, CA 90249
310 - 532 - 9737
Fax 310 - 516 - 8203
www.ariaspistons.com
BRC Performance
615 Industrial Ave.
Live Oak, FL 32064
800 - 522 - 7478
386 - 364 - 5623
Fax 382 - 362 - 7960
www.brcperformance.com
Childs and Albert
24849 Anza Dr.
Valencia, CA 91355
805 - 295 - 6695
Fax 805 - 295 - 7253
Deves Piston Rings
137 Nevada St.
El Segundo, CA 90245
310 - 322 - 8484
Fax 310 - 640 - 9854
www.deves.com
Deves Piston Rings manufactures a complete line of piston rings for domestic, asian and european vehicles. In addition, DEVES manufactures rings for most european motorcycles and makes custom ring sets to order for any application.
Diamond Racing Products
23003 Diamond Dr.
Clinton Township, MI 48035
810 - 792 - 6620
Fax 810 - 792 - 1105
Ferrea Racing Components
2600 NW 55th Ct. Ste. 238
Fort Lauderdale, FL 33309
954 - 733 - 2505
Fax 954 - 735 - 2179
Grant Piston Rings
1360 N. Jefferson St.
Anaheim, CA 92807
800 - 854 - 3540
714 - 996 - 0050
Fax 714 - 524 - 6607
JE Pistons
15312 Connector Ln.
Huntington Beach, CA 92649
714 - 898 - 9763
Fax 714 - 897 - 2724
www.jepistons.com
KB Performance Pistons
4909 Goni Rd.
Carson City, NV 89706
800 - 560 - 4814
www.kb-silvolite.com
KB Engine Parts
5/21 Bayswater Rd.
Bayswater, Vic. 3153 Australia
03 - 9720 - 6133
Fax 03 - 9720 - 7601
www.angelfire.com/biz/kbengineparts/
index.html
Mail Order and Internet Parts Supplier, specializing in camshafts, pistons, gaskets, technical software and books for most popular V8 automotive engines. The Southern Hemisphere's leading engine parts specialist.
Omega Pistons Ltd.
Oak Barn Rd.
Halesowen
West Midlands, B62 9DW, U.K.
0121 - 559 - 6778
Fax 0121 - 559 - 6779
Perfect Circle / Division of Victor Dana Corp.
1945 Ohio St.
Lisle, IL 60532
419 - 891 - 1900
Fax 419 - 891 - 1938
Ross Racing Pistons
626 S. Douglas St.
800 - 392 - 7677
310 - 536 - 0100
Fax 310 - 536 - 0333
www.rosspistons.com
Speed Pro Division
Federal Mogul Corp.
Box 1966
Detroit, MI 48235
810 - 354 - 7700
Fax 810 - 354 - 9936
Total Seal
11202 N. 24th Ave. Ste. 101
Phoenix, AZ 85029
602 - 678 - 4977
Fax 602 - 678 - 4891
www.totalseal.com
Venolia Pistons
2160 E. Cherry Industrial Circle
Long Beach, CA 90805
562 -_ 633 - 9439
323 - 636 - 9329_
Fax 310 - 633 - 9439
Weymouth Pin Manufacturing Ltd.
Units J & K, Lynch Lane
Weymouth, Dorset, DT4 9DN, U.K.
1305 - 767174
Fax 1305 - 767074
www.weypin.co.uk
Manufacturers of piston pins for high performance engine builders and piston manufacturers.
Wiseco Pistons Inc.
7201 Industrial Park Blvd.
Mentor, OH 44060
800 - 321 - 1364
216 - 951 - 6600
216 - 951 - 6606
www.wiseco.com
Wiseco Pistons Canada
948 Keyes Dr.
Woodstock, ONT N4S 7X6, Canada
800 - 265 - 1029
Old Nov 11, 2003 | 03:08 PM
824x4ride's Avatar
824x4ride
i appreciat the help brian!
Old Nov 11, 2003 | 03:27 PM
824x4ride's Avatar
824x4ride
well after going over the sites you listed brian so far i have found some flat top 351m pistons on the rossracing page only problem is they are 586.24 for the set that kind of takes a chunk out of my ***. but hey high performance isnt cheap right.?.
Old Nov 11, 2003 | 07:08 PM
Brian S's Avatar
Brian S
Before you get ahead of yourself
I looked at the Ross pistons and they were listed under custom forged pistons with a vague description like "Ford 302, 351, 400 Cleveland & ""M"""
Flat Top 19-10 $586.24
There was only 1 part number listed so I'm guessing it means for 302C, 351C and 400M. They probably don't know Fords well enough to know that 400M is not the correct term, and they also use a larger .975" pin.
Most of these custom pistons are made from Chevy blanks and use a .927 Chevy diameter pin.
The 351M piston has an unusually tall CH of 1.947" This is the tallest, heaviest, 4" piston Ford ever made and I'd be surprised if there was a Chevy blank available for a custom forged piston.
This is also one of the reasons why a 351M does not like to rev high. The heavier the piston, the more load it places on the rods and crank.
The other reason is the crank. Even though the 400 was based on the 351C, the crankshaft is 13 lbs heavier. The longer stroke, larger diameter main journals and the massive counterweights makes it weigh almost as much as a 460 crank.
Since the 351M came out 4 years after the 400 was designed, Ford took a couple short cuts. They just destroked the heavy 400 crank, and instead of making longer rods they made taller pistons. For a low speed, heavy duty application it worked fine, but for a high revving big horsepower engine it's not a good idea.
The internals need to go on a diet. A 351W crank may be a possibility. If so, there are a lot options. I'll see if I can find a combo that can use some off the shelf pistons.
Old Nov 11, 2003 | 11:32 PM
824x4ride's Avatar
824x4ride
i really appreciate the help brian this engine build up is becomming a pain in the ***.....but thanks man!
Old Nov 12, 2003 | 05:11 AM
Brian S's Avatar
Brian S
I have a few ideas
What kind of budget do we have? Application? Will this be a complete rebuild?
I have a couple 427ci combos and one 383 I just came up with.
Old Nov 12, 2003 | 08:03 AM
824x4ride's Avatar
824x4ride
well budget wise is going to be anywere from 2000 to 3500 not a complete rebuild just a top end rebuild basically i have a brand new motor that is bone stock so i am wanting to squeez as much out of it i can. the application will be some road mostly offroad its just going to be a toy.
Old Nov 12, 2003 | 12:40 PM
Fordtrucker400's Avatar
Fordtrucker400
Where can I find 400 pistons
