We own an old fuel truck and the rotor of the ignition is so much out of tolerance that we need to replace it.
does anybody know which partnumber ours is and where to order one in the US?
That appears to be a rotor for a 6 Cly. if so, it is a Standard FD105. Ford used that rotor in a bunch of engines for a long time so it should be easy to find. Standard Ignition Distributor Rotor FD-105 | O'Reilly Auto Parts (oreillyauto.com)
E-Bay, just find someone who will ship international. There are several hundred on there.
Thats the same rotor thats used on 1950- 1964 4cyl tractor dist. There is a clip that goes on shaft that holds rotor snug on shaft. If missing it flops all over the place.
