2021 F150 2.7ECO 4x2 towing capacity
I am new to towing and trying to calculate how much I can tow with my 2021 F150 2.7 4x2 XLT.
I want to tow two Harley's that combined weight is 1550 lbs ,
Trailer 7x14 Curb Weight: 2,120 Lbs.Payload: 4,880 Lbs., ,
inside my door jam it states
GVWR 6400LB
1591lbs for tire and loading info.
GVWR 6400LB
It can get confusing. You should be able to find your exact (or close to) numbers straight from the source.
https://www.ford.com/cmslibs/content...0_r4_Oct20.pdf
If you weigh your truck, you will know how much payload you have available, but that trailer with the bikes is not going to add much weight to your truck. The majority of the trailer weight will be on the trailer. I don't know the tongue weight of your trailer with the bikes on board, but it can't be much so it is not going to reduce you payload by much. What do you intend to carry in the bed of the truck? It looks like you are well within your trailer payload.
Not a showstopper if that size(7x14) trailer / payload doesn't have brakes, but they sure do help.
HotLoad
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
10-02-2020 10:48 PM
LoudMic
25
11-03-2019 07:23 PM
