Need some gear recommendations
Old Mar 18, 2022 | 12:36 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Alright guys, I'm moving closer to doing gears on Dauntless, and I need some recomendations for which brand and part number i should get, I don't want to end up with whiney or cheap gears, i want to do it right.
This is a RWD so i do not need a front and rear set, just rear. And I have decided on 4.30's.
If this was my GT i would not need help as i have delved neck deep in those drive trains, but I am not a heavy truck drivetrain guy, so I am looking for people who have done them already to give me options for what is the best, reliable, factory quiet option.
I also need the bearing and seal kit if there is one, For the GT when i had the whole axle pulled and rebuild wheel to wheel there was a hardware kit that included all the seals, bearings, and other bits, etc, etc... If such exists for this that would be ideal.
I will be having a shop do the install, But I want to source the parts myself.
Old Mar 18, 2022 | 01:53 PM
ScaldedDog's Avatar
ScaldedDog
Make sure the shop you want to use will do the work with customer-sourced parts. It's common in the 4WD world for shops to not want to do that.
As for parts, you can probably find everything you need here. One of these days I'll build an axle for my crawler (likely a 14 bolt or Dana 70, not a Sterling), and will likely get my parts from East Coast.
Mark
Old Mar 18, 2022 | 01:56 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
I only use shops that allow me to source parts, got that part under control
Old Mar 18, 2022 | 03:11 PM
DesertSmoker's Avatar
DesertSmoker
Locker or no locker?
Old Mar 18, 2022 | 05:26 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
So im not sure what i want to do there, does anyone know if the factory diff on RWD with 3.73s is a posi, or limited slip, or what?
Old Mar 18, 2022 | 05:32 PM
Dweber85rc's Avatar
Dweber85rc
It could have come either way. I would spend the money on quality bearings and seals like timkin. The brand of gears themselves is less important IMO. Other than the brand owned by Yukon that is factory seconds, US gear seems to ring a bell. Since 4.30 is a factory ratio you may be able to find NOS oem as well. I see them occasionally.
Old Mar 18, 2022 | 05:49 PM
Bently_Coop's Avatar
Bently_Coop
I was looking at Nitro gear and Axle, master install kit looks to come with quality components.
https://www.nitro-gear.com/Ford-10-5.../mkf10.5-a.htm
https://www.nitro-gear.com/Ford-10-5...0.5-430-ng.htm
Revolution is supposed to be a solid brand too.
​​​​​https://www.revolutiongear.com/produ...on_long_pinion
Old Mar 18, 2022 | 05:50 PM
Bently_Coop
What does your door sticker say? If you have a LS it is a clutch based. Otherwise a open differential. True-trac seems to be the general consensus either way here.
Old Mar 18, 2022 | 07:23 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
It is a 2000 XLT from a government fleet, and the door sticker does not even have an axle code, its blank, i have already checked.
Old Mar 18, 2022 | 08:27 PM
Dweber85rc's Avatar
Dweber85rc
Speaking of which, just found one https://minneapolis.craigslist.org/w...454508680.html
Cocky EX's Avatar
Cocky EX
Should have come from the factory with a metal tag under one of the diff cover bolts?
Old Mar 18, 2022 | 08:30 PM
ScaldedDog's Avatar
ScaldedDog
The factory limited slip is likely long worn out by now, anyway, so I wouldn't worry about it. As others have mentioned, TrueTrac is the ticket, and would be very worthwhile in a 2WD rig.
Mark
Old Mar 18, 2022 | 10:11 PM
JAck19's Avatar
JAck19
I'll second the TrueTrac nomination. I absolutely love mine, and the grip it adds in inclement weather is great. I had a LSD in all of my previous trucks and I was never fond of the way they lock/unlock. The TT operation is seamless and quiet.
Old Mar 19, 2022 | 09:11 AM
bluovl's Avatar
bluovl
The shop I used here allowed me to source and bring all the parts. They supplied the labor. I used Yukon Master Overhaul kits. They come with everything needed for specific applications.
Master Differential Rebuild Kits | Yukon Gear & Axle
Old Mar 19, 2022 | 09:13 AM
bluovl's Avatar
bluovl
BTW, I have my old front (D50) and rear housing (Sterling) with 4.30 LSD available.
