Cast Iron Headers
Old Mar 17, 2022 | 07:08 AM
SwampRattFord's Avatar
SwampRattFord
Cast Iron Headers
I've got a '66 with FE 352. I'm looking at the FE cast iron headers is an effort to keep the truck period correct (as possible). I've seen there are some early '60s shorty cast iron headers and then some later 60s long tube headers. These are purported to fit the 390s and I'm assuming my 352 is the same as far as the exhaust bolt up is concerned. Am I correct that either the shorty or long tube 2 bolt (upper and lower) cast iron headers would bolt on to my 352?
I've see some discussion of these headers here on the form but the search didn't get me there.
Old Mar 17, 2022 | 09:04 AM
1966F100SC's Avatar
1966F100SC
They would bolt on yes, if I am thinking of the correct ones from the early 60’s. Now clearing the frame…may be another story
Old Mar 17, 2022 | 09:55 AM
Sortofa65's Avatar
Sortofa65
Kugel Components makes them $750. I believe. From what I've read, from them, people have put them on trucks but one side of the frame needs to be notched. They are repo's of the car headers. I don't have any first hand knowledge.
Old Mar 17, 2022 | 01:20 PM
KO1960's Avatar
KO1960
The originals are difficult to find and may not fit. Boss had a recent post where he installed the ones from Kugel.
Old Mar 17, 2022 | 01:27 PM
SwampRattFord
I've emailed Joe Kugel and they still make them, About 800 bucks.He is going to send me some info
about the frame notch that is required on the passenger side. Very responsive.
Old Mar 17, 2022 | 01:34 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The Kugel ones don't have the extra protrusion on the outside of the headers so they may fit on the passengers side without the need to notch the frame. There is a good inch difference not having them. Here's a thread with videos I made of the fit using some original shorty cast iron headers.
352...to build or not to build one Hi-Po - Page 3 - Ford Truck Enthusiasts Forums (ford-trucks.com)
In that thread you can see the headers sitting on the table and the protusions are visible. Drivers side is actually bigger but I didn't have clearance issues on that side. Automatic truck, though, so no clutch linkage to contend with.
Old Mar 17, 2022 | 08:56 PM
buck5050's Avatar
buck5050
those look great. Does anyone have info on restriction stock manifold vs cast iron headers ?
Old Mar 17, 2022 | 09:12 PM
SwampRattFord
A little info that talks a bit about the stock exhaust manifolds.
https://www.diyford.com/ford-fe-engi...omplete-guide/
Old Mar 18, 2022 | 04:33 AM
Swampedge's Avatar
Swampedge
This is what you have to do. These are original Ford units. 1/2” of the frame has to be notched. Hope this helps. Info may not apply as this is a 63 4x4 frame.
Jim
Old Mar 19, 2022 | 11:42 AM
BarnieTrk's Avatar
BarnieTrk
Very Nice, Swampedge!
Are those installed without any gasket ?
Maybe a smear of High-Temp silicone only ?
- BarnieTrk
Old Mar 19, 2022 | 01:11 PM
SwampRattFord
How do they fit on the drivers side. Any issue with steering box and or shifter linkage?
I suppose the key measurement would be from the engine block to the outside of the flange to see what kind of space is required for them to fit.
Old Mar 19, 2022 | 01:35 PM
Swampedge's Avatar
Swampedge
Barnie, just steel against steel. No sealer of any kind.
The steering in my truck is the same as a F600.
It is a manual floor shift truck so no column linkage.
Old Mar 19, 2022 | 05:36 PM
BarnieTrk's Avatar
BarnieTrk
Swampedge,
Thanks for the reply.....
I assume you had the cyl head exh flange face and the header flange face machine-surfaced to ensure they were smooth, flat and square ?
BarnieTrk
Old Mar 19, 2022 | 05:45 PM
Swampedge's Avatar
Swampedge
Of course. Ima machinist tool maker by trade. I can do anything in my garage an engine builder can do except dyno. LB LH SD ext. One man show!
Old Mar 19, 2022 | 08:29 PM
GJCAT's Avatar
GJCAT
Cast headers
Have any of you guys thought about using FT cast headers? They are center dumps like the Yblock rams horns. You can block the center exhaust crossover by welding a stainless patch on them. I`m using a set on a 410 I`m building for my 64 F350. Should clear both sides with little or no cutting of the frame rails and should clear the steering and clutch linkage too.
