On 1978-1979 2bbl 351m/400 trucks with factory cruise there is a little plastic l bracket i=on the side of the carb that engages the toilet bowl chain and it seems easy to break. I had a few spares but it looks like I am down tomy last one. the number on the bracket is d7ta-9c876aa. I need a few if possible.
A few? I just wired & zip tied mine to the throttle pull rod. Looking back on it, it might look neater to do the wire & zip tie, leave chain straight, then cover the loose end with a piece of large shrink tube, then snap the rod back on the carb ball.
