Installing heated steering wheel?
Old Mar 15, 2022 | 11:25 AM
Joe T's Avatar
Joe T
I want the leather wheel. How hard is it to install the heated wheel? If it requires wiring changes I can’t get to at this time will everything else work ok (clock spring misc the same?
I have sync 4 in my STX. It has the power accessories, 120v plug, productivity screen, 360 cameras,and trailer brake and yaw sensor misc. So it should have similar wiring to higher optioned truck.
Old Mar 15, 2022 | 11:52 AM
TB250's Avatar
TB250
Search for Raptor heated steering wheel here on the site. Easily done.
Old Mar 15, 2022 | 06:43 PM
Joe T's Avatar
Joe T
Perfect that would cross over to the regular steering wheel then.
Old Mar 15, 2022 | 07:44 PM
4wd6.7L's Avatar
4wd6.7L
From what I have seen it requires the correct clock spring, heat control module and custom harness. If you had all that installed, just not wired for heat, I suppose everything should work.
Old Mar 15, 2022 | 10:53 PM
Mikelikesit's Avatar
Mikelikesit
Hey Joe, the Raptor threads are in here. Theres a regular member whos selling ustom harnesses for different needs.
I cant remember his name.
Seems to me something about a goose. But my memory isnt worth ten cents.
But hes mentioned on the raptor wheel threads for sure.
Old Mar 16, 2022 | 01:35 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
BoostedGreyGoose.
https://www.boostedgreygoosedesigns.net
Old Mar 16, 2022 | 08:37 AM
Joe T's Avatar
Joe T
Got it ordered. Funny but recently they were out of stock and didn’t reply to an email, I looked a few months ago.
Do these usually have 1 or 2 pins on the airbag? I could ask on the raptor thread but do not want to get them off track unless last resort.
I think I will use a platinum wheel and platinum black arm rests on the door panels.
Brandon Hess
Jan 18, 2022 11:09 AM
cabindoc
6.7L Power Stroke Diesel
May 31, 2021 07:23 AM
sjshook
2009 - 2014 F150
Dec 12, 2020 05:21 AM
Captain_Morgan
Nov 29, 2020 02:39 PM
