have a PTO from a t98 trans that I'm trying to get seals for with no luck so far.The only id i see on it is it's a spicer and there's a number on a bearing cover of PTO NO.AANF 7-12 anybody have an idea where to get parts, Thanks
You may be relegated to taking it to a local bearing/seal shop where they can measure the seals and shaft and whatnot and find a suitable component in their manufacturer/supplier books.
Hi, Don't know what part of Michigan your in,there is a bearing seal store in Livonia,just south of 96.
I have a PTO off a T98 as well, I removed dump on my truck,so PTO is under work bench now.
the folks at this store are very helpful and would be glad to help you.
iffin you would like I could find the name of said store.
A pair of calipers for diminsions /sizes would help you too,or get a buddy to measure if you don't feel comfortable with it.
Good luck
Greg
