Door panels
Old Nov 6, 2003 | 10:09 PM
Fcapw's Avatar
Fcapw
Question Door panels
will 83 door panels with the push down locks work in an 80 ford with the slide locks??
If so what kind of work will be required to get the locking mechanisms to work???
Old Nov 7, 2003 | 11:03 AM
locknkey's Avatar
locknkey
No they will not work...different linkages are involved.
Old Nov 8, 2003 | 10:13 PM
steve83's Avatar
steve83
I think the '80 latches have the necessary holes in the levers, so I think you could use those panels if you swap in the '83 lock button rods. If that won't work, the '83 latches will certainly fit in the '80 doors.
But if you can find a set, the '92-96 door panels are much better, with 2 storage pockets each. The drawback is that you MUST swap your vent windows to the '92-96 style with flat fronts.
itlives
Aug 10, 2013 10:04 PM
aussiecowboy
May 29, 2012 10:31 PM
Bootlegger's Deluxe
Feb 13, 2012 11:22 PM
rhelm22
Sep 25, 2006 05:28 PM
