Weird 4 amp draw.
Old Mar 13, 2022 | 03:52 PM
Ferd f-teenthousand's Avatar
Ferd f-teenthousand
4wd High
Weird 4 amp draw.
So, my battery in my 1995 F350 (5.8 C6 2WD crew cab) keeps going dead.
I got my volt meter out and disconnected the negative battery cable, and ran the volt meter in series set to the amps setting and plugged into the appropriate places on the meter.
I have a 4 amp draw coming from somewhere!
I started under hood, then to the cab fuse boxes pulling the fuses and relays one by one watching to see if the amps drop off...Nothing!
So, going back to the fender mounted relay i unplugged the two fusable links and the drain went away!
Now, here is where it gets interesting!
if I plug one or the other fusible links in (one to the alternator and one to the fuse box?) the 4 amp draw comes back.
My question is: does this mean the relay is toast?
is there something I'm overlooking?
Thanks in advance.
~Kyle
Old Mar 13, 2022 | 08:03 PM
aquartlow's Avatar
aquartlow
Could be a bad rectifier diode within the alternator, may want to take it and have it tested if something else isn't obvious.
Old Mar 13, 2022 | 09:27 PM
Ferd f-teenthousand
4wd High
I forgot to mention I unplugged all three connections to the alternator (D-Shaped plug, B+, and the small grey one) basically isolating the alternator from the rest of the circuit. Still had an amp draw of 4 amps.
Old Mar 19, 2022 | 01:04 PM
Ferd f-teenthousand
4wd High
Ok, so I revisited the alternator.
and I have to admit, you were correct.
I only plugged in the wire to the alternator from the solenoid, and I was getting my amp draw. I unplugged the D shaped plug at the alternator and it stopped.
thank you aquartlow!
Old Mar 20, 2022 | 07:49 PM
aquartlow's Avatar
aquartlow
Glad to help.
koden
22
Dec 19, 2017 09:43 AM
mezcalero280cal
Dec 12, 2014 05:08 AM
Cole Neese
107
Feb 22, 2014 11:40 PM
1979ford
Electrical Systems/Wiring
Mar 3, 2007 09:42 PM
cntryboy0531
Jun 18, 2004 08:03 PM
