Low Voltage to Fuel Pump
Old Mar 13, 2022 | 12:55 AM
Angel Garcia's Avatar
Angel Garcia
Got a 1992 F150 with low voltage to the pump. Was running fine until it rained and ran fine after that but a day later, the truck would only crank but wouldn’t start. I did a pressure test at the injector railing and had nothing, I also didn’t hear the fuel pump come on either. I have done voltage test to different locations as instructed by my teacher and I’m getting 12.6 volts to the fuse, and pin 85 on the relay. Im also getting 12.6 volts at pin 30. It’s at pin 87 is where I’m getting a weird reading. When I turn the key to run, it reads 12.6 for half a second then drops down to 8.5 after that. My teacher said it could be a bad fuse box. I wanted to have another opinion on it.
Old Mar 13, 2022 | 01:19 PM
rla2005's Avatar
rla2005
The fuel pump relay is energized for 1-2 seconds when you cycle the key from the Off to Run position. After that time period the relay is dropped out. Cranking the engine over will produce pulses from the PIP sensor which "tells" the computer to energize the fuel pump relay, pulse the injectors and fire the coil.
The ~8 VDC you are measuring is expected when the supply voltage is removed and the circuit is open. This is VERY normal operation.
First suggestion is check the inertia switch behind the passenger side kick panel to see if it is tripped off.
Also start reading this thread with very similar issues as you have stated: https://www.ford-trucks.com/forums/1...fuel-pump.html
ET1993Ford
Dec 24, 2023 10:13 AM
Angel Garcia
Mar 12, 2022 08:12 AM
Krystal Ford
1997 - 2003 F150
Sep 25, 2021 04:40 PM
FX4-350
Feb 22, 2014 03:27 PM
MV7
Jul 5, 2013 03:27 PM
