Sponsored by: Auxito
Low Voltage on fuel electrical
Old Sep 25, 2021 | 01:12 PM
Krystal Ford's Avatar
Krystal Ford
Angry Low Voltage on fuel electrical
Hi, I have a problem with my fuel pump not turning on. I have just returned from a vacation and gone to work for two day. The truck got me home, but when I went to start it the next morning, I could not get it to start. I checked and was not getting any fuel pressure. When I check the voltage at the distribution box relay, I am only getting 6.3 volts. And That is the same voltage I am getting at the cut off, and at the pump itself. Does anyone have the diagrams or could tell me where to look to trouble shoot the problem? I am not even sure the pump is bad at this point.
Old Sep 25, 2021 | 02:42 PM
projectSHO89's Avatar
projectSHO89
Ignore it, it's a "red herring".
What is the voltage during the priming cycle? That cycle is only 2-3 seconds long after the key is turned from OFF to RUN and is the reading that actually matters.
Old Sep 25, 2021 | 04:40 PM
Jon Freeman's Avatar
Jon Freeman
There are numerous threads on here, and other forums, about low voltage to the fuel pump. You may want to scour those first.
fferd
1997 - 2003 F150
50
Mar 10, 2025 09:16 AM
Bing03
Oct 18, 2017 03:29 PM
the_breadman
Jul 29, 2007 04:47 PM
lamzee
Aug 26, 2006 02:18 PM
Rhood
Electrical Systems/Wiring
Nov 1, 2005 09:41 PM
