Sponsored by: Auxito
2003 tune up
Old Mar 12, 2022 | 08:19 PM
wisconsincanman's Avatar
wisconsincanman
2003 tune up
My 2003 F150 is approaching 100,000 miles. Runs great, has the 5.4 in it. Thinking about getting the old girl a tune up. New plugs, wires, fuel filter, change transmission fluid, new belt, change antifreeze. What else? I plan on keeping her and getting another 100,000. Any thought's ? Thanks !
Old Mar 13, 2022 | 12:13 AM
Jon Freeman's Avatar
Jon Freeman
Check the owner's manual for stuff to do at 100,000. i am thinking the PCV valve is due to be replaced. Air filter if it hasn't been done recently. If your going to do the coolant, check your hoses and maybe the water pump and thermostat. but those are optional.
Old Mar 13, 2022 | 07:19 AM
manicmechanic007's Avatar
manicmechanic007
All the fluids
All the filters
Give it a 30k service
Lube all the door hinges and window tracks lube drivelines if applicable
Bunch of inspections
Do everything in the owners manual +
Old Mar 30, 2022 | 02:57 PM
On Holiday's Avatar
On Holiday
I have an 03 with 115k miles, purchased it new in 2002. Mine's going in for some work as I sprung a leak under the hood. I'm also due for new tires, rotors and pads.
Old Mar 30, 2022 | 04:24 PM
WWR's Avatar
WWR
Excellent point, if OP wants to be proactive just do the intake manifold replacement before it starts leaking coolant.
Old Mar 30, 2022 | 04:39 PM
manicmechanic007
Not sure it is in the owners manual any more but ford (used to) would replace your PCV valve for free at 100 k miles if you ask them to
Old Apr 4, 2022 | 11:54 AM
On Holiday's Avatar
On Holiday
My leak was due to the power steering tube rusting out. It's all fixed as of this morning.
Old Apr 7, 2022 | 06:27 PM
J. Bruce's Avatar
J. Bruce
I like to clean the mass air flow sensor every once and a while with the appropriate cleaner. Also check the throttle body for cleanliness but if you do need to clean it do your research on the protective coating, I just use a dry shop towel and be gentile.
Old Apr 13, 2022 | 04:38 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Idler pulley, tensioner, and verify the fan clutch still works well. Maybe voltage regulator brushes, they run about $6.
I am not a fan of 20 year old plastic end tank radiators, I would swap if in budget. The dual row one from an Expedition drops in and is what is in my '01 Screw.
Old Apr 20, 2022 | 05:40 PM
SDDL-UP's Avatar
SDDL-UP
I was able to use a pair of Vice Grips to crimp my radiator back together on my 2000 F-150. It hasn't leaked in the years since.
If I could find one of these trucks with low miles I'd go get a loan and buy it! 300,000+ miles on mine.
Old Apr 25, 2022 | 04:52 PM
Stonedpony's Avatar
Stonedpony
One of my trucks will not run on Ford plugs but love the G force plugs and I get 100,000 miles out of them. Use Ford coils and I know they are not cheap, but well worth the time and money for them.
Builder123
1997 - 2003 F150
Mar 12, 2013 09:00 PM
baracade
2004 - 2008 F150
Jul 22, 2010 11:27 PM
tvvbsn
Modular V8 (4.6L, 5.4L)
13
Jul 28, 2004 09:28 AM
Nightrain
20
Jun 29, 2004 09:10 AM
equium
Mar 18, 2004 08:39 PM
