Sponsored by: Auxito
Over Drive "OFF" not Engaging
Old Mar 12, 2022 | 01:21 PM
F150_4x4's Avatar
F150_4x4
Old Mar 12, 2022 | 02:02 PM
Jon Freeman's Avatar
Jon Freeman
here's a discussion that may help
https://www.f150forum.com/f6/overdri...working-99693/
Old Mar 12, 2022 | 02:28 PM
projectSHO89's Avatar
projectSHO89
The suggested thread isn't likely to be of any use.
It helps if you explicitly identify your truck. Can't provide specific recommendations without knowing what's involved. Could be a blown fuse, bad switch or indicator, a damaged wire harness, or the PCM.
Old Mar 12, 2022 | 04:10 PM
enriched&beyound's Avatar
enriched&beyound
maybe the light bulb is burnt out on the shift lever ?
Old Mar 12, 2022 | 04:34 PM
F150_4x4's Avatar
F150_4x4
Old Mar 12, 2022 | 05:42 PM
Jon Freeman
Something must have went screwy because now the overdrive button does not indicate "off" when pressing the shift level overdrive button.
Check the fuse for the overdrive. It will be identified in the owner's manual. If it's blown then you may have a short in the wire from the switch. There's some videos out showing this problem and the fix.
Won't hurt to check for codes too.
Old Mar 12, 2022 | 06:46 PM
projectSHO89
There's nothing in or near the underhood fusebox that has anything to do with this issue. It's a coincidence, most likely.
The fuse for that circuit is F29 under the dash. Check it first although if blown there may be other symptoms. Autolamp, if equipped, is also on that circuit.
If the fuse is okay, pull the column shrouds and inspect the little harness that comes out of the shifter tube looking for any evidence of wire damage.
After that, it gets harder as you have to do actual troubleshooting.
Old Mar 12, 2022 | 07:13 PM
F150_4x4's Avatar
F150_4x4
Old Mar 12, 2022 | 07:31 PM
F150_4x4's Avatar
F150_4x4
Old Mar 12, 2022 | 07:36 PM
F150_4x4's Avatar
F150_4x4
Old Mar 12, 2022 | 08:33 PM
projectSHO89
Originally Posted by F150_4x4
I looked up the overdrive control button and it's #28 fuse in power box under the hood as a source of the problem.
I don't know what you looked up, but the 2000 F150 doesn't have a "#28 fuse" in the underhood fusebox.
If you want help, follow directions. If you want to wander off on your own, you'll be exactly that - on your own.
Read directions. Follow them. Report observations and results.
OTOH, if you're convinced that the mechanic broke it, take it back to him for repair.
Old Mar 12, 2022 | 10:10 PM
F150_4x4's Avatar
F150_4x4
Old Mar 12, 2022 | 10:54 PM
Jon Freeman
This is a video showing a fix for the OD not working. It's not for your specific vehicle and I'm not saying this is your problem but it is worth a check.
Old Mar 13, 2022 | 12:46 AM
F150_4x4's Avatar
F150_4x4
Old Mar 13, 2022 | 07:23 AM
manicmechanic007's Avatar
manicmechanic007
The shift lever has wires that break around 100 K miles with normal use (way sooner on a plow truck or work truck)
A scan tool can tell you real quick if the switch or wiring has failed
I keep one new lever in my toolbox and a new switch
