Top end upgrades!
Old Mar 12, 2022 | 06:55 AM
ccarrier's Avatar
ccarrier
Top end upgrades!
It’s been a long while since I’ve posted!
Recently made some purchases to freshen up the truck a little and will be installing slowly in my free time.
238/80 bitterroot diesel injectors
comp beehive valve springs
Smith bros pushrods
arp head studs
riffraff diesel stainless injector cups
and finally installed my hydra
Shooting for the 500 mark
Anything I’ve missed that I need to purchase ?
Old Mar 12, 2022 | 07:26 AM
FinnishStroker's Avatar
FinnishStroker
Do studs one in a time, don't mess with headgaskets.
If cups ain't leaking,don't mess with them.
Old Mar 12, 2022 | 07:29 AM
ccarrier's Avatar
ccarrier
I have already replaced the cups already. I am doing studs one at a time. Working on the springs first.
Old Mar 12, 2022 | 04:14 PM
Hit Man X's Avatar
Hit Man X
Traction, tires, trans.
Old Mar 12, 2022 | 05:25 PM
idshred's Avatar
idshred
What turbo?
fuel system?
manual or auto trans?
Old Mar 12, 2022 | 08:00 PM
ccarrier's Avatar
ccarrier
covered , covered , covered
Old Mar 12, 2022 | 08:01 PM
ccarrier's Avatar
ccarrier
Originally Posted by idshred
What turbo?
fuel system?
BB 38r ( sd conversion )
electric fuel
zf5
Old Mar 12, 2022 | 08:12 PM
z31freakify's Avatar
z31freakify
A freshen up of the heads wouldn't hurt (new valves, new valve seats, ported head, but I have no clue what mods are needed to make 500hp on these engines either so theres that.
Old Mar 12, 2022 | 08:22 PM
97-psd's Avatar
97-psd
I haven’t seen you around much lately. Glad to see you still have the truck. If you have the time and $$ and are looking at the 500hp target, I would give some thought to upgrading the 38r. There have been some pretty strong updates since that turbo was really popular. If not, enjoy it as is and let us know how you like the 238s
Old Mar 12, 2022 | 09:50 PM
idshred's Avatar
idshred
this! If it’s in the budget, a t4 kit with a borg warner sxe turbo sized appropriate to your needs seems like it would be hard to beat.
I have my 2001 7.3 apart right now and am putting a stage 2 kc turbo in it with the same injectors you bought. I doubt I will be near 500 hp though as my tuning will be more conservative as I have PMR’s. Depending on your primary uses and gears/tire size you could use a stage 2 or 3. Stage 3 would get you to 500 easier I would imagine.
Old Mar 13, 2022 | 09:02 AM
ccarrier's Avatar
ccarrier
after speaking with the injector builder and the tuner, 500 is going to be reached with the 38r. I plan on keeping it as I really enjoy it.
Old Mar 13, 2022 | 09:03 AM
ccarrier's Avatar
ccarrier
as of now I’m sticking with the 38r. I really enjoy it.
Old Mar 13, 2022 | 09:36 AM
FinnishStroker
38r has stock size turbine.
There's quite a bit of exhaust from 500hp..
EGTs,EBPs through the roof and possible surge expected.
I'm running Holset HX50 86/72 turbine,16cm housing and NO intercooler.DIY 205/80 hybrids.
EGTs maxes out at 1100f in "normal" driving.
(I think that even 86/77 turbine would work in my application)
Old Mar 13, 2022 | 10:45 PM
nomad221's Avatar
nomad221
Spoiler
In what shape is your ZF5 ? Drivetrain ? 2WD or 4WD ? Which clutch and FW package are you considering installing ? 500hp is gonna break stuff.
Christian1977
Transit Connect
Dec 30, 2017 10:24 AM
ford1341
Mar 20, 2014 06:41 AM
mototrig
15
Jun 10, 2013 10:14 AM
florida_1959
Feb 10, 2010 02:43 PM
hotshothauler
Oct 7, 2005 06:46 PM
