4wd not engaging
Old Mar 11, 2022 | 02:09 PM
Jim TN's Avatar
Jim TN
4wd not engaging
My 02 excursion sets more than its driven and does not want to shift into 3wd. Have tried different motion stuff and on/off stuff with no success. What do I need to pull off to fix it. I know where the changer is and would like to know about what to do to it.
Old Mar 11, 2022 | 02:16 PM
Antonm's Avatar
Antonm
Have you tired manually locking in the hubs?
Old Mar 11, 2022 | 03:34 PM
Jim TN's Avatar
Jim TN
Thanks for reminding me. I just started it, put it in 4wd and checked the front driveshaft, it was locked in so it has to be a hub problem. Since I do not have manual hubs, guess I am going to have to replace the autos with manuals.
Old Mar 11, 2022 | 03:55 PM
Dweber85rc's Avatar
Dweber85rc
Well that is an option, but if your factory hubs have the ability to manually lock and you really are not gaining anything over aftermarket in terms of functionality. Both will lock the axles manually for 4wd.
Old Mar 11, 2022 | 04:08 PM
WE3ZS's Avatar
WE3ZS
Your factory auto hubs can be turned from AUTO to LOCK.
Old Mar 11, 2022 | 09:43 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
There is so much to check for free before blowing money on aftermarket hubs...
Is the light coming on the dash indicating the transfer case actually shifted to 4x4 and is turning the front drive shaft?
Old Mar 12, 2022 | 07:31 AM
roadrnnr's Avatar
roadrnnr
It is fairly simple to service the factory hubs with the procedure linked below. I have 180k on my '05 and they still work fine. I do this roughly once a year. ALso checek thte tech folder for info.
https://www.ford-trucks.com/forums/1...excursion.html
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Mar 12, 2022 | 04:12 PM
00t444e's Avatar
00t444e
Does the light on the dash come on when you switch to 4x4 and did you lock the hubs?
archer_ski
Apr 6, 2013 06:11 PM
Bryanblaylock
Feb 4, 2013 01:53 PM
shameless
Mar 12, 2009 06:45 PM
tuekwik
Mar 5, 2007 12:23 AM
rogerwilhere
Offroad & 4x4
Jul 6, 2006 07:05 PM
