Sponsored by: Real Truck
1999 v10 PCV valve
Old Mar 10, 2022 | 11:35 AM
jziegler's Avatar
jziegler
1999 v10 PCV valve
Does the engine have two of them, one on each side? I have a hose doing to the intake from both cylinder covers.
Old Mar 10, 2022 | 12:17 PM
manicmechanic007's Avatar
manicmechanic007
One PCV valve only, the other side is a vent
So if it is working correctly the PCV valve is sucking hard enough to make a slight vacuum on the other hose.
The test is to pull the vent hose and put a small piece of paper over the hole in the valve cover
It should suck the paper tight to the valve cover
That means there is no excessive blowby and the PCV valve is working and is not plugged up
Chopper_WSP
Modular V10 (6.8l)
Jul 19, 2008 11:24 AM
rg200amp
May 2, 2008 12:31 PM
BAJI26
Mar 16, 2008 01:24 PM
biz4two
Modular V10 (6.8l)
Oct 28, 2006 11:36 PM
baitboy
Jul 9, 2001 03:52 PM
