True rear diff ratio
Old Mar 11, 2022 | 02:47 PM
BDWSD22's Avatar
BDWSD22
Size matters,...
Originally Posted by chadstickpoindexter
Thanks for the link. But, I'm still not exactly sure where to start? When choosing an F250 with 6.7, 4x4 and 3.31, the XL trim starts with a 245/75R17 tire, and an XLT (my trim) lists the first tire size as a 275/65R18 tire. I understand that the actual (hard cut steel) gear ratio is a 3.31, but (if this makes sense) which tire size would this most relate to to effectively be 3.31 at the tire? Or maybe I am (still) over thinking this?
For example:
When using 3.31 as the stock gear ratio and I start with the smallest XLT 275/65R18 tire option and go to the 275/70R18's, the effective gear ratio is 3.2
When using 3.31 as the stock gear ratio and I start with the smallest 245/75/R17 tire option on the XL F250, and go to the 275/70R18's the effective gear ratio is 3.14.
But:
When using 3.31 as the stock gear ratio and I start with my 275/70R18's and go to the 285/75/R18's, the effective gear ratio is now 3.15.
When using 3.31 as the stock gear ratio and I start with the 245/75/R17's and to to the 285/75R18's, the effective gear ratio is now 2.9.
So, I would assume that when we pick the 3.31 rear end, to get this effectively at the tire, Ford would base this on the smallest diameter tire that is an option?
I don't guess it doesn't really matter at this point... I already have the truck, these are the tires I have on it, and I can't say I have any issues. When it comes time to replace them I will go with either the same size on it now, or bump up to the 35's (like the DuraTrac's that come on the Tremors), but I have been curious, and then when seeing this thread made me decide to ask about my own situation. Just trying to figure out what my effective gear ratio actually is with my set up. Thanks for any help.
I had a 2020 F-350 6.7 w/3.55 which is the lowest ratio that you can order. I upgraded from the stock LT275/70R18" to 275/65R20" with no adverse affect on towing an 11klbs RV nor hauling more than a ton of dirt in the bed. If in doubt, shift to manual and lock out 10th gear with your 3.31:1 gears. All I noticed was that the larger tires were harder to balance and the speedometer was 3mph less than actual.
Old Mar 11, 2022 | 03:57 PM
powerboatr's Avatar
powerboatr
I have a hard time wrapping my brain around this... I went with the 3.31's and the GY 275/70R18 wheels which have a 33.2" diameter and 630 revolutions per mile. I have the PSD and only pull a 6000 lb GVWR camper, so didn't figure I'd really even need the 3.55's... but I did start wondering what my actual (effective) ratio is with the slightly larger tires, and what it would look like if I decided to go with a 35" tire when it comes time to replace them. But I'm guessing, like mentioned above, the effective ratio on mine isn't really 3.31, and it's probably quite a bit lower than that?
1050 ft lbs of tq makes up for alot of tall gears (3.31) which is what i have. I wanted 3.55 but the tq in 67. lets you get away with it and still have lots of hmmmpf to the road.
but yes tires overall circumference does make a difference in final drive ratio. it will be taken into account when i get new tires as well.
Old Mar 12, 2022 | 04:19 PM
speakerfritz's Avatar
speakerfritz
Very confusing
i have a 4:30 which came with 19 inch rims and I believe 33 tires.
i put 22.5’s and 37’s on it….does that mean my effective is 4:10.
Old Mar 12, 2022 | 06:01 PM
WE3ZS's Avatar
WE3ZS
Originally Posted by speakerfritz
Very confusing
No, it means that you now have an effective 3.84 ratio based on the 33” to 37” tire change, the wheel size is totally irrelevant.
I swapped 4.88 gears on my EX because I knew I was going to be running 35” tires and I wanted the effective 4.30-ish ratio that works so well with the V-10 that it has, with my 35.25” Nittos I now have an effective 4.39 ratio based on the tire size difference between the factory 31.6” and the 35.25”s.
Pacific Fisher
Oct 23, 2020 04:27 PM
Pastor Scott
Dec 2, 2016 09:28 PM
blueovalman
Modular V10 (6.8l)
Feb 18, 2008 09:49 PM
BroncoRoadKill
25
Feb 17, 2006 08:13 PM
darkman
Jan 2, 2002 07:01 AM
