BLIS issue
Old Mar 8, 2022 | 06:34 PM
cgraham69's Avatar
cgraham69
7th Gear
BLIS issue
I have 2020 F250 Tremor. I broke the light on the passenger mirror. Went to fix it, when I took the glass mirror off, I accidentally pulled the wires from the BLIS LED indicator.
Well I could not get the wires back into the plug properly. So I need a new plug/pigtail to fix it. Look everywhere and could not locate the pet number. When to Ford and a 20 year parts supervisor couldn’t find it. Doesn’t show up anywhere.
Any help?
to clarify. On the actual glass there are 3 plugs. Two for the heater, and one for the BLIS. I need a BLIS pigtail.
Old Mar 8, 2022 | 06:53 PM
Doug Savage's Avatar
Doug Savage
…. sounds to me like you’re probably headed to a salvage yard…..
Old Mar 8, 2022 | 07:08 PM
cgraham69's Avatar
cgraham69
7th Gear
Doug, called all mine in the area. None have any f250’s or even f150’s.
Old Mar 8, 2022 | 07:12 PM
Doug Savage
Dang…. Have you tried any of the on-line salvage? And I wonder if you’ll have to buy the whole glass assembly?
Old Mar 8, 2022 | 07:13 PM
Doug Savage
Or….. I bet those could be soldered back in??
Old Mar 8, 2022 | 07:14 PM
cgraham69's Avatar
cgraham69
7th Gear
Ya searching now. Can’t believe Ford can’t even figure out the part on their own 70k vehicle.
Old Mar 9, 2022 | 09:37 AM
Ding126's Avatar
Ding126
Call Lawrence at Boostedgraygoose...he may be abgle to make sometging or has something
Old Mar 9, 2022 | 09:46 AM
BackingOut's Avatar
BackingOut
You are asking for just the plug - If you want it from the dealer, you will want to ask for the harness. Just the way it is a lot of the times.
Old Mar 9, 2022 | 10:15 AM
cgraham69's Avatar
cgraham69
7th Gear
They don’t sell the harness for the mirrors. Told me I would have to but the whole mirror. $1500
Old Mar 9, 2022 | 11:02 AM
BackingOut's Avatar
BackingOut
I just searched real quick in this forum and the F150 - I think you will find what you need to get a part number for the plug.
Old Mar 9, 2022 | 12:28 PM
whagen's Avatar
whagen
if you can figure out the style of connector, you could probably buy the connectors, pins and crimp tool.
Old Mar 9, 2022 | 05:49 PM
jrx13's Avatar
jrx13
Are you talking about just the little indicator in the mirror that lights up? I can't see that thing anyway! Just do what a couple of us did and add a light on the mirror trim and forget that useless light
https://www.ford-trucks.com/forums/1...ndicators.html
Old Mar 9, 2022 | 07:01 PM
HorizontalHunter's Avatar
HorizontalHunter
You might find your connector in here:
https://www.motorcraft.com/content/d...-Book-2016.pdf
Bob
Old Mar 9, 2022 | 07:16 PM
cgraham69's Avatar
cgraham69
7th Gear
Thanks. Already checked that site. It’s not there.
Old Mar 10, 2022 | 12:42 PM
TB250's Avatar
TB250
Any numbers on the connector housing? A lot of the connectors on the truck are Molex MX150 series connectors available from Digikey, Mouser and other electronic supply houses.
