302 Build Cam Selection
Old Mar 9, 2022 | 10:14 AM
Forddude91's Avatar
Forddude91
Originally Posted by DaveMcLain
If I was selecting the cam for an application like this I would probably use a single pattern cam with a duration of about 190-195@ .050 on a 107-108 lobe sep and put it in the engine on about a 105. I think that would be pretty close. This is thinking that the actual compression ratio will end up around 8.5:1 which should be fine.
I have a 302 in a '65 Galaxie and I built that engine 30 years ago. It has an Engine Power cam that's a dual pattern 190 intake 202 exhaust on 108. That engine has 9.5:1 compression and it requires premium fuel. It runs surprisingly awesome in a 3800lb car. That cam would be better with lower compression if I wanted to run it on 87 octane but it was the first car engine that I ever built and that was a long time ago.
I never ran that engine on a dyno but based on my experience from other engines since then it probably makes about 310lbs/ft of torque, maybe 315.
is there a cam you can recommend since this is my first build im not sure what I need to choose
Old Mar 9, 2022 | 12:01 PM
DaveMcLain's Avatar
DaveMcLain
I doubt that you'll find a cam with those specs sitting on the shelf but most cam grinders should be able to grind something that's close. I wonder if cams like this will become more popular again now that fuel prices are getting so high?
Old Dec 9, 2022 | 09:19 AM
pltommyo's Avatar
pltommyo
1st Gear
What is the EP cam ID you are running? I worked there (my dad was a co-owner) and had a 289 with a custom grind modified EP32B that was very nice in my '67 Galaxie. Now we have a '91 Bronco with a 302 that we converted to MAF and are ready to have some fun. The original owner was running a Ford 303B in it, but I know we can do better with MAF and new set of GT40P heads we have on a shelf. Time to go through cams and pick a nice roller that will give us a fun lope and still be drivable.
Old Dec 10, 2022 | 08:35 AM
DaveMcLain's Avatar
DaveMcLain
I don't know what the EP part number would have been. I bought it through Sealed Power. Lots of cam companies sell the Engine Power cams and there are many good ones in their line as long as you watch out for the ones with lobe seps that are wider than optimum.
Engine Power supplies a lot of UGL cores to cam grinders and those have been is very short supply for a while. I've read that it is a very small part of their business but I wonder when the supply problems will be easing. Any ideas?
Bootlegger's Deluxe
30
Jul 11, 2017 09:46 PM
resto-mod
Jan 17, 2013 11:20 AM
aj197816134
Nov 21, 2010 12:26 PM
chrisbrown67
15
Oct 29, 2009 11:01 AM
