Scangauge needed
Old Mar 7, 2022 | 06:18 PM
tshrager's Avatar
tshrager
Scangauge needed
What’s the recommended scan gauge for these trucks? I have a aero force for my 7.3 and wondered if there’s something similar to monitor a 6.7.
Old Mar 7, 2022 | 07:47 PM
senix's Avatar
senix
Tbere is also a banks Idash that works by plugging into the OBD port.
Old Mar 7, 2022 | 08:42 PM
Overkill2's Avatar
Overkill2
Scott has an iDash as I do also. Check out this thread for info:
https://www.ford-trucks.com/forums/1...nks-idash.html
Edge Products also make digital monitors as well.
Some guys use FORscan on a tablet/old phone and there's also the Torque Pro app that's supposed to be good.
Old Mar 7, 2022 | 08:50 PM
chadstickpoindexter's Avatar
chadstickpoindexter
I have the Banks iDash Data Monster. I’m still learning about it though and is the first and only monitor I have ever used, so I can’t give comparisons. I do like it though. It’s pretty simple to set up and use and there are tons of parameters that can be monitored… I just need to learn what many of them are and what the normal readings for all the different parameters are.
I will also add, I liked that the Data Monster allows me to record tons of data, however, mine is mounted near my knee and the Micro SD card loads from the front and sticks way out… I’m afraid I’ll hit it with my knee and break it off, so I don’t leave the card inserted… so I can’t actually record the data. If you mount the iDash up on the dash it likely isn’t an issue though. Also, the Data Monster is significantly more expensive than the regular iDash…
I will also add that I ordered the Banks mount for $45… it’s cheap garbage. It should have been $6… I would look elsewhere for mounts considering the price they ask for theirs.
Old Mar 7, 2022 | 09:28 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
We love the iDash.
Old Mar 8, 2022 | 05:13 AM
senix's Avatar
senix
some alternate mounting ideas
Old Mar 8, 2022 | 10:54 AM
Overkill2's Avatar
Overkill2
On the windshield for me... easy peezy. I like the custom mount though Scott.
Old Mar 8, 2022 | 02:11 PM
chadstickpoindexter
I would eventually like to mount it in the pillar like the photo above. I don’t like the window mounts because so many seem to have that glue on them now which in my experience doesn’t fare well in constant hot temps… it was a mess. Plus it gets in the way when putting my windshield visor up. I have seen some trims that fit around the vents with a cup molded into them too that look nice. For now though, I’m going to get my use out of this crappy $45 mount… lol.
Old Mar 8, 2022 | 02:58 PM
tshrager's Avatar
tshrager
Thanks for the responses guys. Do the idash and CTS3 read and clear codes?
Old Mar 8, 2022 | 03:01 PM
chadstickpoindexter
The iDash will. I can’t say for certain it reads and clears every single code though.
Old Mar 8, 2022 | 10:10 PM
jollyrogr's Avatar
jollyrogr
Someday I’d like to have an iDash for monitoring while driving but for now I do have Forscan which can do monitoring if you bring your laptop along. Forscan can obviously make configuration changes and clear any DTCs. The cost is minimal since you only need to buy the OBD adapter. Forscan recommends the OBDlink EX and I do too as it works flawlessly.
Old Mar 9, 2022 | 07:23 AM
tshrager's Avatar
tshrager
Can you download an app onto a tablet and use a OBD wifi connector?
Old Mar 9, 2022 | 08:22 AM
jollyrogr's Avatar
jollyrogr
Sure, they have Forscan lite available for IOS and Android. You can't do programming with the lite versions though. But that would be an option for a scangauge and DTC clearing tool. The OBDLink MX+ bluetooth adapter is recommended for that.
Old Mar 9, 2022 | 11:12 AM
Overkill2's Avatar
Overkill2
Is OBDlink EX the wired version?
Old Mar 9, 2022 | 11:45 AM
jollyrogr's Avatar
jollyrogr
Yes the EX is the wired version.
Dutter 2
Mar 18, 2016 11:56 PM
Brian Garrett
Mar 16, 2015 11:17 PM
Harvester93
Dec 31, 2012 10:12 PM
jmt22
Mar 2, 2011 06:34 PM
jeff7825
Ford Truck Parts for Sale
26
Dec 7, 2009 08:23 AM
