6.2L V8 Discuss the 6.2L V8
Upper Radiator Hose Leaking
Old Mar 7, 2022 | 07:48 AM
saratoga2011's Avatar
saratoga2011
I noticed some odd drips up front and found the quick connect on the upper hose to the radiator leaking after 9 years and 102K miles. Some research and a phone call later, I found that the upper hose does not need to be replaced, that the o-rings in the coupler are available separately and that this leak is apparently pretty common.
I was due for a coolant change anyhow and was surprised to find a petcock and a hose barb to drain the coolant.
The offending flattened and leaking o-ring is just behind the white cone shaped plastic piece.
Back together and ready to be refilled with coolant in less than an hour.
Here's the P/N for the o-rings.
stlcardinal
Apr 23, 2021 04:59 AM
89LX306
6.7L Power Stroke Diesel
Dec 26, 2020 08:33 PM
Ford.Dude
Oct 27, 2018 10:56 AM
killacal
May 21, 2016 04:39 PM
bradahl
1997 - 2003 F150
Jan 30, 2011 07:19 AM
