Vacuum reervoir
https://shop.broncograveyard.com/OEM...ctinfo/207900/
This one is actually for the speed control, I'm looking for the can that sits on the drivers side inner finder.
It's for the HVAC controls. I have the small ball but if a little is good too much is just right.
And some ND input. https://www.ford-trucks.com/forums/1...hings-for.html
Ball/round one: D0DZ-19A566-A .. Plastic Vacuum Reservoir: 1973/75 F100/350 // 1970/71 Torino; 1970/72 Maverick/Comet; 1971/72 Pinto/Bobcat.
I know the above reservoir is plastic, but I don't recall if the following D6TZ reservoir is or is not. Car/truck parts catalogs aren't any help, as they don't give descriptions.
D6TZ-19A566-A .. Vacuum Reservoir: 1973 Pinto/Bobcat/Maverick/Comet; 1976/77 F100/350; 1978 F100/350 & Bronco before serial number AJ0,001.
This "coffee can" shaped reservoir is steel: D7OZ-19A566-A .. Vacuum Reservoir: 1978 F100/350 & Bronco from serial number AJ0,001; 1979 F100/350 & Bronco // Misc: 1977/79 FoMoCo Passenger Cars.
The one on my 81 F100 had pin holes all along the bottom where it rusted through.
I pulled off the mounting bracket and coated the can in fiberglass rosin. Once hard I painted it
, put the bracket back on and works like a champ.
Dave ----
Dave ----
