I ordered a set of axle seals for a small bearing 9 inch rearend and they just came in today. They are Timken 51098. I was surprised when I opened the box and found that the seal material is leather and not a synthetic rubber with a spring. Is this normal?
Suspicious... is the seal Chinese? I wonder if it's a counterfeit? Did you buy from Amazon? I replaced a 9" small bearing axle seal about 3 months ago and it was the usual rubber with gaiter spring, but it may have been a National Seal.
Not sure they are as good or better than some of the new products, but there have been many leather seals used in the past. I would not hesitate to use it if it fit correctly.
Also as long as it is fresh-made. I imagine soaking it in oil before installation is proper?
The leather is supple but also very thick, they will get a soaking in rear end lube prior to install.
This is the rearend that they are going into, I am replacing it with an 8.8 and 4-link...
Don't use leather seals. Not only will they always seep a little, they are very abrasive. They will wear right into the surface, so next time around you will be guaranteed to need speedi-sleeves. I have rebuilt tons of vintage trucks, equipment, machines, etc., and anything with a leather seal always has a damaged seal surface.
Chuck
I would have to disagree. It has been my experience that rubber seals are more abrasive than leather. One of the main ingredients of rubber is clay. They will both wear a groove in the sealing surface.
Mark
