oil pressure?
Old Nov 6, 2003 | 05:00 PM
modru2004's Avatar
modru2004
oil pressure?
i just had the trucks oil and all fluids checked and changed. well on the gauge im still getting a reading in between low and the n of normal. its about half way in the middle. the highest i have seen it go is to the n. it should be ok right? trucks in my sig, 150+k miles on it. not sure exactly ill have to check again.
Old Nov 7, 2003 | 05:06 AM
pfogle's Avatar
pfogle
Get a real gauge and install it. You will find that it's just a problem with the gauge on the dash. Is it making noises? Lifter ticks, bearing rattles? Sounds like a bad connection at the "switch" the dash gauge is nothing more than a "smart" idiot light.
