cab bushings
Old Mar 1, 2022 | 11:38 AM
wrongway01's Avatar
wrongway01
cab bushings
How many in here have replaced the cab mount bushings? I have a set of S&B coming and looking for tips or tricks to get the old ones out.
Old Mar 1, 2022 | 12:34 PM
Robfinger's Avatar
Robfinger
Big sawzall, Milwaukee Torch blades, soak the old rubber in WD40 overnight beforehand. You did get the bolts out, right, they ain't stuck? And you're new kid does come with the steel snout thing said bolts pass thru?
Old Mar 1, 2022 | 12:49 PM
R&RFord's Avatar
R&RFord
I am in the middle of this project...
Cleaning up the threads on the mounting bolts made my life a lot better getting the old bolts out. Penetrating oil, wire brush, and I actually ran a die up and down the portions I could. I am going to need a helper on one as the mount is spinning.
I have successfully used the provided press set up to separate one set of bushings, but it failed on the second. The threaded rod is bending...
So, I am planning to get a 5/8 drill bit and drilling out the fitted towers from inside the cab, unless someone has a reason I shouldn't do this... The other notions I have seen is to beat them apart with a hammer or cut them apart with a saw.
Old Mar 1, 2022 | 12:55 PM
yardbird's Avatar
yardbird
My bushings are starting to sag, and slightly crack. You guys are certainly not making me want to get under there and take on this project anytime soon.
Does no one sell the whole 9 yards where you just unbolt, and bolt new in?
Old Mar 1, 2022 | 01:05 PM
tommywvk's Avatar
tommywvk
Couldnt find the OE cab sleeves that the bolt passes through for my bronco but I know a guy who custom makes them and tig welds them together that sells on ebay. Very good quality and comes with all new bolts washers and such, I used energy suspension poly bushings on top of them. I would cut the old sleeves out
sandymane's Avatar
sandymane
I plan on doing mine someday and saved this information from a forum thread. It sounds like it would work well but I haven't tried it.
https://www.ford-trucks.com/forums/1...ab-mounts.html
Old Mar 2, 2022 | 05:55 AM
wrongway01's Avatar
wrongway01
Bushings should be in the mail today. I'll go ahead and start spraying lubricant on everything and tackle it this weekend. Sounds like a tedious job for sure. Thanks for the tips
Old Mar 2, 2022 | 09:55 AM
McLeod's Avatar
McLeod
I did mine years ago.
Leave the bolt in place but back it off so it is only a couple thread turns into the lower nut and then you smack the heck out of bolt with a BFH trying to drive the bolt downward.
Use lots of penetrate fluid too.
About the time you are thinking it is a useless exercise it will [hopefully] come apart.
The upper sleeve and the lower sleeve interlock.
Once you get them apart you will want to wire wheel them clean.
Then cut off the flared part of the sleeve that locks into the opposing side before reassembling so it is easier to separate next time
If you just cut the sleeve apart with a sawzall while it is in the truck's frame you are weakening the ability of the mount to stay rigidly mounted and in place.
One mount cut apart with sawzall like this may not cause a problem but if you just cut them all off like this there is more chance of problems.
You will need patience for this project and your arm will be tired from swinging that BFH at awkward angles.
Depending on the rust level, this may take all day to do. Usually the core support mounts are the most difficult to remove of all of them.
Old Mar 2, 2022 | 11:13 AM
Scndsin's Avatar
Scndsin
I did the energy suspension full kit with bolts. Worth every penny.
Didn't need to destroy/cut anything, save the core support mounts, (real mother for'ya) but I guess advantage of GA 1 owner truck.
Old Mar 2, 2022 | 11:37 AM
R&RFord's Avatar
R&RFord
With the kit the OP bought there is no need to save any of the hardware, except the large washers under the bolt heads.
At the end of the day yesterday I put a bolt in the bottom of the mount that wasn't coming apart and filled that sucker with penetrating oil from the top. Removed the little bolt from the bottom this morning, stuck a long grade 8 bolt in from the top and went to town with a hammer, and it came apart pretty quick. So, now I have all the hardware apart, and lower mounts off except for the driver side rear, which I am going to need a helper to get the bolt out due to the mount spinning...
My advice to the OP... once you get the mounting bolts out, put a bolt back in from underneath and fill those suckers up with penetrating oil and let em soak before you try to separate them.
Old Mar 3, 2022 | 12:04 PM
Diesel_Brad's Avatar
Diesel_Brad
So S&B supplies new steel hardware with the bushings?
Good to know
Old Mar 3, 2022 | 01:41 PM
R&RFord's Avatar
R&RFord
Good to know
Removal tool, mounting bolts, hardware, bushings, assorted shims... it is a well put together kit. Only things I have reused is the extra large washers on the rear cab bolts, and at the radiator core support.
I am just about done with my install, and am happy with everything. The cab is just a touch proud compared to the bed, but I assume it will settle a bit over time.
Old Mar 3, 2022 | 02:30 PM
GoinBoarding's Avatar
GoinBoarding
How does the S&B bushing material compare to OEM? Similar softness? I have Energy Suspension poly mounts currently, and really dislike how harsh they are with some of the roads I drive.
Old Mar 3, 2022 | 02:36 PM
tommywvk's Avatar
tommywvk
Sharing this here for anyone who cannot find replacements for future reference.
Ebay store with locating sleeves/bushings, not affiliated
https://ebay.com/usr/vintage4x4
Old Mar 3, 2022 | 03:14 PM
mat-it's Avatar
mat-it
Any chance you could measure the height of each new mount down one side of truck from where they touch the frame to cab. I don't see that dimension on the SB site and want to check if my stock mounts are indeed sagging.
