Engine Temperature displayed by Numbers on Information Cluster
I was towing, in high heat on a grade with AC on, a digital displayed of a numbered (ex 195) temperature appeared on the Information Cluster. The number changed increasingly, then it decreased and then it disappeared. There were no messages or warning displays associated with it. I have never have seen this before.
Have any of you experienced this? Is this a new addition to the F250 or as it always been there? There is nothing in the manual. I have at least 30,000 miles of towing with no change in setup, but episode mentioned is the only July trip.
Look forward to any feedback 😀
Rick L.
intofire56a@gmail.com
Setup: 2019 F250 6.7 Diesel Lariat Crew Cab short bed, 2019 Grand Design 2600RB (tongue weight 800lbs)
I believe the number will display when engine coolant temperature is deemed to be at a critical level. Then it disappeared again when your temp reached a normal level.
Mine did the same thing after plowing. Was going down the highway with plow on and skidloader trailer behind and mine started posting temp. Slowed down a bit and it went down and off.
