Alright folks, looking for opinions. I have an 89 351w just back from the shop. Started putting together last week. Installed the crank and torqued the main caps in sequence to 100 ft/lb. Here’s the question….. the bolts were dry. Should I pull it back apart and oil the threads and retorque? Pistons are in, heads are bolted on with ARP bolts and used the arp lube on the head bolts. Thanks for sharing your thoughts. Just keep reading that the main bolts should have had a drop of oil on them before installing…..
I mean they weren’t doused in oil. They were pretty dry. I’m thinking it would be best to just break them
loose, leave the caps on as they are, oil and re-torque….
If your second guessing your work, absolutely.
I'd be worried that now the bolts are torqued, may be stretched, good time to get new bolts, or check yours again.
You know, I'd have to look at some sort of actual specification, but I've always used motor oil on the threads of my Rod and Main bolts, when installing them. I don't know if it's something that's required, or just something I do because that's the way my Dad taught me to do it.
Oiled vs dry threads will impact the clamping force for a given torque applied, due to the frictional losses in the threads. Dry-dry will deliver less clamping force (more torque goes to friction) than oiled. That's why I was asking how dry they were. I think I'd pop the bolts out, oil, and reassemble too. The piece of mind would be worthwhile.
That is specified in the FSM.. assemble the 351w with SAE 50 wt engine oil. Any engine work I’ve ever done, on anything, is always assembled with engine oil unless otherwise specified or thread sealant etc.
What would concern me is that you did not achieve the proper clamping load. Especially on main bearings. Ie. The hardware may be at torque, but not clamping down as they should be if done with lubrication.
I'm doing some heads, and was concerned about my bolts. If your pulling your end cap bolts, and they are used, you may want to check this video out:
Basically, using simple callipers, you can tell if you bolts are bad or good and will know if you need to replace or not:
