Another question
Old Feb 27, 2022 | 11:49 PM
triorez25's Avatar
triorez25
Another question
I've got some questions about the head and taillights in ny 84 f150 name are my markerlights meant to be on when the full headlights are and how do i make it so my rear directional lights are more noticeable when i have my lights on?
if it weren't obvious I'm pretty new to trucks abd stuff so sorry if this is a dumb quest​​​​​​
Old Feb 28, 2022 | 01:38 AM
FuzzFace2's Avatar
FuzzFace2
When you say marker lights would that be the side marker and the lights just under the head lights?
As fot rear turn lights they should blink brighter that tail lights.
Should be as bright as the stop lights as it uses the same part of the 1157 bulb.
Is the bulb getting dimmer when blinking? If so check the grounds to the lights not working right.
Dave ----
Old Feb 28, 2022 | 02:04 AM
triorez25's Avatar
triorez25
Dave ----
Yes i mean the side and lower lights and I'm not sure how to describe it but they're ridiculously dull for some reason despite the break and normal tail light being fine i know they're new bulbs and i don't think they get dimmer though the headlights do when i let off the throttle
Old Feb 28, 2022 | 03:26 AM
FuzzFace2's Avatar
FuzzFace2
Are the lights on and just dim or not on?
Your not using LED bulbs are you?
Head light relay installed on the truck?
Dave ----
Old Feb 28, 2022 | 07:07 AM
triorez25's Avatar
triorez25
Dave ----
My bad yes the blinkers come on but oddly dim no leds and yes there's a relay
Old Feb 28, 2022 | 07:28 AM
Max Capacity's Avatar
Max Capacity
Are the tail light lens stock or after market ?
Old Feb 28, 2022 | 09:57 AM
BigBlue2's Avatar
BigBlue2
For good bright tail lights, parking lights and marker lights:
1. Clean the plastic lenses inside and out.
2. Clean, corrosion free bulb sockets. These sockets came from the factory with a dab of anti corrosive conductive grease. If you drive on salty roads you can protect the connections with an anti corrosion conductive treatment.
3. Good solid ground connections to the frame.
4. Replace bulbs when they get old. The more hours on the bulbs the dimmer they get.
Old Feb 28, 2022 | 02:44 PM
triorez25's Avatar
triorez25
They're stock
Old Feb 28, 2022 | 02:47 PM
Max Capacity
Originally Posted by triorez25
They're stock
I'll refer you back to post #7 then.
Old Feb 28, 2022 | 02:48 PM
triorez25's Avatar
triorez25
Roger thanks
Old Mar 1, 2022 | 10:11 AM
kr98664's Avatar
kr98664
Here's a troubleshooting guide for you:
https://www.ford-trucks.com/forums/1...ing-guide.html
Specifically, look at the dual filament bulbs and make sure the correct filament lights up. Also, park in a dark location, and see if any other bulbs illuminate dimly when not commanded.
emeraldcoupe
Oct 17, 2018 10:57 PM
christurney77
1947 and Older Ford Trucks
Feb 1, 2013 12:47 PM
Tuxedo Scorpion
Offroad & 4x4
40
Jul 11, 2012 12:55 PM
The67Beast
Sep 25, 2006 11:06 AM
