I love not having a captured spring. Shock changes are a breeze now. I had a captured spring style shock on my previous trucks and it sucks to work on. I'm sure there are advantages but, for how I use my heavy duty truck, I'm not seeing it.
we run king coilovers on our toyota, love them. but maintenance is a pain. not to mention rod ends make more noise on the shock mounts anyways.
Yeah, but that's an IFS set up that was made to run coilovers. I know with IFS, you can start messing with the overall travel as well so the captured spring makes sense with that type of suspension. With a solid front axle, I don't know what you gain by switching to a coilover. I wonder if you could find an Ori setup that works with the truck, that would be pretty sexy, although same as a coilover, not sure what you're really gaining by doing that.
These guys are legends in the off road world and here a couple of videos why they prefer coilovers
Carli did a write up on this. You actually loose travel with the coil over.
Travel is important because you can run a bit softer spring as it has more time to dampen the impact where less travel has less time.
Go watch some YouTube videos of Carli trucks and how they handle off road. It speaks for itself.
Do you have a link to the article or write up on this?
I am going to send PMF an email about the travel numbers going with a coilover suspension setup versus a seprate coil spring and separate shock to see what they say.
Just looking at the way, it's mounted on PMF's website, it seems like you could use a longer shock and get more travel out of the way that PMF mounts the coilover. I could see it adding some complexity but I don't see that being an issue.
Also, here is the link and the description of Carli's coilover system for the 11-16 super duty's
"Providing height adjustability, dual front shocks and ultimate bottom-out resistance, the Coilover Bypass kit is the best option for the avid off-roader. 2.5″ Coilover and 2-Tube, 2.5″ bypasses adorn the front wheel well, while 3-Tube Rear Bypasses and Full Progressive Leaf Springs round off the rear. This system maintains great on-road manners and is the most off-road capable of our 4.5″ lift lineup."
Suspension travel and offroad performance aren't always synonymous with each other. Comparing travel between that coil over kit and their pintop kit shows the pintop(non coilover) having more available travel up front. .9" lol. I have read through a couple of your threads and it's been said numerous times how important maximum suspension travel is to you, but I haven't noticed what your intended use will be. The type of offroad locations you plan to use the truck where all the travel will be needed and used.
I think that CJC exclusively uses Carli so it's a little funny to me that on the 11-16 Super Duty's that the Coilover was the second most expensive option they had on that generation
