Fire issue 2017-19 diesels
Old Feb 24, 2022 | 10:13 PM
dieseldrew's Avatar
dieseldrew
Does anyone know for sure what the culprit or issue has been with the 2017-19 6.7 catching on fire ? Seems the majority have started in the engine compartment and it looks like most have started on the drivers side. Small fitting (return) on the secondary filter breaking off perhaps ? As many diesel trucks in this year range that have caught fire I would think this would have been a safety issue enough for a recall of some kind for a fix.
Old Feb 24, 2022 | 10:35 PM
4wd6.7L's Avatar
4wd6.7L
How many have caught fire? I've only seen mention of a few. There is a problem with the engine mounted fuel filter. They sometimes spring a leak and spray deisel all over. There is a recall on them but only a limited year range, not 17-19. I have heard it blamed on lack of maintenance, as in not replacing them soon enough....I don't buy that. I think Ford should take a look at how they can beef it up, IMO a fuel filter should never burst no matter how many miles are on it.
Old Feb 24, 2022 | 11:01 PM
mattymax's Avatar
mattymax
Seems the majority of the fires are due to the failure of the engine compartment plastic fuel filter. Almost the luck of the draw on a mast produced part. Some fail, most won’t.
Old Feb 25, 2022 | 11:27 AM
dieseldrew's Avatar
dieseldrew
4wd6.7L - if you search for a 6.7L engine thru any of the salvage yard venues, you can see a lot have had fires besides the normal carnage from close encounters with all sorts of items.
Seeing a lot that have had fires got me a little concerned so this is why I'm asking. If nothing else maybe do some preventive measures to head off such an issue. My first act will be to purchase a good fire extinguisher to carry. It's a good idea to have one anyhow, right ? Never thought of this before until seeing the end results of not having one. Guess they call that hind sight !
Old Feb 25, 2022 | 11:30 AM
speakerfritz's Avatar
speakerfritz
yes, the return fitting on the engine bay fuel filter breaks as well as cracks in the plastic fuel filter housing.
they come out with a clam shell protector for the fitting.
dont know what they did about the cracks in the plastic housing.
diesel normally does not flash at atmospheric pressure so more needs to be understood on why some flash and some dont. perhaps gas in the diesel.
my hose popped off once. no fire. but fuel every where.
I installed the new clam shell connector and used a squeeze clamp on the hose.
Old Feb 25, 2022 | 11:31 AM
SARDiverDan's Avatar
SARDiverDan
If mine catches fire, I will let it burn. No way would I want them to try and fix that. While some may have had issues with a fuel filter, how many others are self-inflicted by rigging up wiring to add accessories with folks that have no idea what they are doing.
Old Feb 25, 2022 | 11:35 AM
Joe T's Avatar
Joe T
There is a retrofit part to address it.
There is probably little to no old parts left to install.
My 2020 is a new design and I think 19 is too.
Old Feb 26, 2022 | 06:03 PM
DEW34's Avatar
DEW34
The problem is the exhaust manifolds and turbo are in the engines valley .When the fuel leak happens the manifolds and turbo are drenched with fuel causing the fuel to vaporize making the diesel much easier to ignite with enough heat .To me the fuel filter is not in the best place for this type of engine arrangement . Being a diesel mechanic for 35 years for a fleet of diesel powered vehicles 2200 of them I have seen plenty of fires but none of them fuel related a lot of electrical fires , hydraulic oil , p/s fluid engine oil but no fuel fires the fires that happened with the mentioned oils all happen when the hot exhaust manifold or turbos were sprayed with hot oils that i mentioned . 90 percent of our engine arrangements were inline 6s exhaust manifold on one side the fuel system on the other side . We have had fuel leaks where they dam near drained the 60 gallon tank fuel spraying on the opposite side of the engine no fires .In my experience thats what I believe is happening . The fuel leak is one thing but the reason why is another . Hope that helps .
Old Feb 26, 2022 | 10:25 PM
CascadeF250's Avatar
CascadeF250
I lost that filter fitting on my 2016 just as I crested Washington pass in the North Cascades in Washington . We had just completed a long steep climb pulling the 5th wheel out of Winthrop. Diesel fuel all over the engine and ground. No fire , good thing as we were miles from civilization of any kind.
akamacgyver
Jun 22, 2012 01:09 PM
tex25025
General Diesel Discussion
May 8, 2009 08:02 PM
whimsy
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 15, 2008 12:58 PM
mikedeason
6.4L Power Stroke Diesel
57
Mar 31, 2007 07:57 AM
SwampBilly
Jun 14, 2006 02:50 PM
