2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Powerboost Payload
Old Mar 17, 2022 | 05:25 PM
sub1187's Avatar
sub1187
One could argue conflicting information but they are using 150 lbs as the standard for two occupants on some of the payload ratings.
Old Mar 17, 2022 | 05:26 PM
personanongrada's Avatar
personanongrada
Originally Posted by sub1187
It wasn't in the manual, that was my mistake. It was in the fleet.ford.com towing guide. It's in small print but it has stated that for years.
What I read in the 2022 towing guide is that the passenger weight mentioned relates to towing capacity, but does not mention passengers in the very short section referencing payload. I think that others are correct in stating that payload is based on no passengers or gear, but full fluids.
Old Mar 17, 2022 | 08:38 PM
personanongrada
I dunno. Here's the fine print from page 2 where payload is shown.
"Maximum towing capabilities are for properly equipped vehicles with required equipment and a 150-lb. driver and passenger and vary based on cargo, vehicle configuration, accessories, option content and number of passengers. Maximum payload capabilities are for properly equipped vehicles with required equipment and vary based on vehicle configuration, accessories, and option content. See label on door jamb for carrying capacity of a specific vehicle. Horsepower, torque, payload and towing are independent attributes and may not be achieved simultaneously. For
additional information, see your Ford Dealer."
The towing capabilities sentence references passengers, but the max payload sentence does not. Don't want to start a war or anything, just want to point it out in case some people rely on that sticker and are close to the wire on the limit. That 300lbs does make a difference. Still, could just be the way I'm interpreting it...
Old Mar 23, 2022 | 12:03 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
The door sticker includes passengers/cargo/tongue weight/accessories/etc. in GVWR, as in curb weight plus passengers/cargo/tongue weight/accessories/etc. shall not exceed GVWR. Even changing tires and rims out for heavier units would need to be added to this. In the end:
1. What does the Earth feel from the overall weight of your vehicle? Is that number higher than the GVWR? If "yes" then you are overloaded. If no then you might not be overloaded, proceed to step 2.
2. What does the Earth feel from the overall weight of your front axle? Is that number higher than the front GAWR? If "yes" then you are overloaded. If no then you might not be overloaded, proceed to step 3.
3. What does the Earth feel from the overall weight of your rear axle? Is that number higher than the rear GAWR? If "yes" then you are overloaded. If no then you are not overloaded.
Same for GCVWR.
Old Dec 30, 2022 | 09:19 PM
wrgrimes's Avatar
wrgrimes
Yellow sticker vs CAT scale
So I took my new truck to the CAT scale today- gas full and no passenger.
King Ranch Standard; Powerboost; 2WD; 7.2KW; 360 Assist and camera
Base weight- 5500#
GVWR- 7350#
Payload= GVWR-Base weight
Payload= 1850#
My yellow sticker- 1787#
I used 2 KR std to estimate my payload
1856# & 1844#
Estimating is difficult due to the lack of information. The Ford tow information is about it, and it is limited, dated, and somewhat cryptic.
ALL of my estimates were well above 1800# using multiple trucks.
Of note, 1787# was assigned BEFORE my truck was built (according to the VIN specific calculator that was operational in October). From my experience of one, Ford is not weighing each individual truck and printing the appropriate sticker.
I am more comfortable with >1800#.
As a pleasant aside- My truck came with the Front Sensing System, which the 2023 Order Guide specifically excluded from 360 Assist. FSS required 360 Active (Blue Cruise).
Happy New Year!
Old Dec 31, 2022 | 06:35 AM
RossRR's Avatar
RossRR
Base weight- 5500#
GVWR- 7350#
Payload= 1850#
1856# & 1844#
Happy New Year!
Well now you got me wanting to go weigh my truck. It's sticker says 1444 but I'd love to see something better.
Old Jan 13, 2023 | 01:50 PM
papadelta's Avatar
papadelta
1st Gear
2022 PB SC Lariat Monroney & Payload
Got this from a used dealer:
Old Jan 13, 2023 | 02:02 PM
wrgrimes's Avatar
wrgrimes
Pretty typical of a fairly loaded Lariat.
61Redneck
Nov 21, 2021 02:16 PM
NSAJMART
Jun 21, 2021 10:51 PM
rblomquist
2015 - 2020 F150
38
Jul 26, 2015 12:19 PM
breadstick
1997 - 2003 F150
Oct 10, 2013 04:38 PM
awsomefords
Mar 30, 2004 04:02 PM
