Have an electrical issue going on, tpms light, brake light, door ajar, back lift gate will not open except sometimes when shutting the vehicle off, dash panel stays illuminated when key is removed and doors are locked causing battery drain. The turn signal indicators don’t flash on the cluster or have the flasher sound clicking. But the blinkers do work on the mirrors and both front and rear. Also the stereo and display cuts on and off randomly.
just spent $1300 on having it diagnosed as the instrument cluster, had it replaced and programmed only to have no issues solved. Every wire diagram I’ve came across leads me to the smart junction box. Although I also believe it can be a bad wire or ground. I’ve also came across threads in other forums with same issues but never any solution. I’m just wondering if anyones ever had a solution to this issue. Getting down to tracing individual wires pretty quick. Thanks in advance for any input
Changed the smart junction box and had it programmed . No luck. Getting into this pretty deep. Next step is to trace all wires and hopefully find a faulty one
