Fuel pump question
Old Feb 21, 2022 | 07:18 PM
Fishin Mike's Avatar
Fishin Mike
Fuel pump question
Hello I have a 1978 ford f250 4wd with the 351M. I am trying to find out if there is a way to check the mechanical fuel pump if the truck won't start. Thank you so very much for the help...
Old Feb 21, 2022 | 08:40 PM
Aggietrucks's Avatar
Aggietrucks
I would disconnect the fuel line where it meets the carb and see if you get gas coming out when you start it and rev it up.
Old Feb 21, 2022 | 10:46 PM
Ozzie H.'s Avatar
Ozzie H.
The 1978 Ford Truck Shop Manual says the fuel pump for the 351M should make 6.0-8.0 P.S.I. with a volume of at least 1 pint in 20 seconds with temperature normalized, at curb idle speed in neutral.
Old Feb 22, 2022 | 09:40 AM
dustyroad's Avatar
dustyroad
If you just crack the fitting to carb, you should see gas when cranking. Unless you do as Ozzie posted and keep the fitting/hose in a container to measure output. This will prevent a lot of gas from dumping on the engine potentially.
The best thing to do is get a fuel pressure gauge also.
I had a mechanical pump putting out 3psi and after 10 minutes it couldn't pump anymore.
the gauge helped figure that out.
Fishin Mike
Feb 13, 2022 05:18 PM
Hunter Green
Jun 28, 2021 03:35 PM
Spktyr
Jan 31, 2016 07:30 PM
DAI532
27
Sep 24, 2009 08:34 PM
