S&B Cold Side Intercooler Pipe
Anyway, I know that there are a few different aftermarket companies out there that make these intercooler pipes. I chose S&B based on lots of good feedback on all of their products, and I am also planning on putting at least one more S&B item in my truck in the future... the 60 gallon fuel tank! I'll also admit that I am considering their CAI too... not because I am expecting/wanting a huge performance increase, and if I'll continue to be honest, I like the way it looks and I don't see it causing any issues with my truck. Also, to a lesser degree, it is tough finding stock air filters right now, but I can get a cleanable one from S&B plus they do seem to have their filters in stock every time I have looked. Again, not saying that a new CAI is important on these trucks, but I am considering it... Anyway, all of that to say, I chose S&B over the other companies because I plan on being a repeat customer and they seem to be well received from multiple sources.
But, I did wonder if going with a 2 piece pipe was a good idea verses 1 piece pipes, but again, I didn't see anything negative about it, so I felt like it was a safe bet. When I ordered it, it was on backorder. I contacted S&B about how long the backorder would last. They responded the same day and told me it was about 2 weeks. I waited a few more days and then pulled the trigger on the order. I ordered on January 21. It shipped February 7th, which was a Monday. I figure they got them back in stock on the Friday before, which was exactly 2 weeks from the date of my order. Of course though FedEx took the long way to get to my house, and decided to hang onto it for an extra day or 2 also, but that's on FedEx, not S&B.
I got around to installing it a few days after I received it. It looked pretty straight forward, but just to make sure I didn't miss a step, I printed the instructions from the website (about 30+ pages... lol!) and got busy. When I took the stock pipe off and compared it to the S&B pipe, there was no comparison... the stock pipe is a bit pathetic. (I wish I had taken a picture of them side by side...) Putting the new pipe on wasn't as easy as taking the old pipe off, but it wasn't terribly difficult either. What I did struggle with was twisting the aluminum pipe so that it slipped inside the silicone hose. The aluminum pipe didn't just slide right in like in the video I watched a while back, however, I think if I would have put just a thin layer of oil on the end of the aluminum pipe it would have. Once I got the pipe all together, I almost made a mistake... for whatever reason, I read the "tighten to 75 in/lb" as 75 ft/lb! Thankfully I realized it before getting carried away and messing anything up! (I pictured myself crushing the intercooler fitting!) Anyway, I didn't have anything to measure 75 in/lb so I just got the hose clamps "snug" and called it good. So far no lights have come on so it must be good and sealed.
Anyway, like I said above, I haven't read of the 22MY's intercooler pipes failing, but I have read about them bursting on recent previous years, so while it may not have been necessary, I feel like I have decreased the chances of having this failure now... plus, the S&B pipe looks way better than the OEM pipe too!
I have shared this upgrade over in the "What did I do to my 22" thread but I also wanted to share it here in the 6.7L PSD group. Also, what really surprised me was I received a phone call a couple of days ago from an unknown number. As usual, I didn't answer it, but later realized I had a voicemail. Turns out, it was S&B just calling to make sure everything arrived as expected and that install went well and to make sure I didn't have any questions. I didn't call them back, but felt like it was a nice touch, and if I do have questions, I wouldn't hesitate to call them. Also, the next day I received a follow up email stating the same as the phone call. So, very nice product, and above and beyond customer service means that I definitely wanted to share my experience, and like I mentioned above, I will definitely be doing more business with them in the future! If anyone is looking to swap out intercooler pipes on their own trucks, I wouldn't hesitate at all about going with S&B!
Just took everything out of the box.
All installed and good to go! It looks much nicer than the OEM pipe too!
Never mind, I see on their site it's 300 dollars.
If or when I do it, I'd go with an SPE Motorsports as the throttle body adapter comes with 3 ports. But I've got more research to do and other things I want before I would go with a system.
I've been back and forth with different CAIs in the past. I had considered many different ones but I do like the fact that the Banks and S&B intakes are CARB approved even though I probably wouldn't have an issue with ones not approved. NY state follows CARB laws but only where the population density is high like NYC/Long Island.
After looking on S&B's website, I do like that S&B replaces the stock intake tube to the turbo but Banks does a lot of testing so I'm thinking that the OEM tube doesn't affect much. I also like the S&B has larger filters, are cheaper to replace and that the CAI from them is cheaper than Banks.
I also like this by S&B:
https://www.sbfilters.com/2011-2019-...6-7-map-sensor
S&B was my second choice.I believe you do not want to use oil to assemble. Silicon lube if anything...
When my cold side pipe gets here I'll install the S&S dpk and new cold pipe at the same time.
I am interested in their filters though, particularly the cleanable ones. I was in the process of buying new OEM filters and Diesel Filters Online actually called me when they had some come in but I decided not to get them after all. I am thinking I will probably just get their CAI sometime soon and just replace it all at once.
Anyway, I wish I had taken a photo of them side by side, but I didn't... but you can see the end of the S&B silicone pipe in the photo in my initial post, and you can tell it is heavily reinforced. I did go out just now and take a photo of the stock pipe, and you can tell quickly that the stock pipe is not near as reinforced as the S&B pipe. Would it have failed? I have no idea... but I am much more confident in the one from S&B.
This is how the plastic ones fail.
https://cimg9.ibsrv.net/gimg/www.for...9da49a26f4.jpg
