More Progress
Old Jul 24, 2022 | 08:49 AM
EBEAR's Avatar
EBEAR
Depending on how you plan on using your truck but we were out 400 miles from home last fall in great weather with our coupe . We got up Monday morning to 38 degree rain turning to slushy snow , no heater and 300 miles from home . Really wished we had a heater .
Old Jul 24, 2022 | 10:21 AM
1949f1's Avatar
1949f1
Thank you. I was thinking about a cigar lighter and a heater that runs off of one just incase. I used one in my polaris before I put a heater in it and it worked pretty good and the cab isn't much bigger in the truck
Old Jul 24, 2022 | 11:20 PM
EBEAR's Avatar
EBEAR
This is what I put in the coupe not much but a little piece of mind .
Old Jul 25, 2022 | 01:56 AM
1949f1's Avatar
1949f1
Looks like it would be worth checking out. Thanks'
Old Jul 25, 2022 | 10:22 AM
CharlieLed's Avatar
CharlieLed
Looking sharp Tracy...it's nice to get to this stage of a build where every change you make can be seen as adding to the overall look of the truck.
Old Jul 25, 2022 | 02:09 PM
1949f1's Avatar
1949f1
Thank You Charlie, It sure does
Old Jul 27, 2022 | 09:41 AM
Vegastype's Avatar
Vegastype
Originally Posted by 1949f1
Thank you. That is what I was thinking too. I did install a 12 volt windshield wiper system in it after this picture was took. I also got all the interior put back in and the two consoles I made.
Is your gas tank in the cab? If not what did you do (if anything) to cover up the back wall?
Old Jul 27, 2022 | 02:17 PM
1949f1's Avatar
1949f1
Yes, the tank is under the bed. I tried to find some pvc board to be able to make the shape I needed to cover the back wall but didn't have any luck. I took some heavy duty Velcro and took some material that I used on the console and made a cover for the area that was open where the tank was. In this picture there are wrinkles that I did get out later. You can't see this with the seats in.
Old Jul 27, 2022 | 09:25 PM
KirkF's Avatar
KirkF
How was your rear fender fit to your bedsides? Did you have to elongate or change the holes in the fenders to match the holes in the bed?
Kirk
Old Jul 28, 2022 | 03:40 AM
1949f1's Avatar
1949f1
Kirk
The rear fenders are fiberglass. They fit pretty good and I had to put them where I wanted them and mark the holes for drilling. With them being fiberglass you need to drill the holes a little bigger and use rubber washers and bigger washers to cover them so the glass don't crack. They fit so much better then the aftermarket steel front fenders did.
Jdeshler
Dec 23, 2021 03:51 PM
martin72
146
Sep 22, 2017 11:01 AM
eberf
15
Oct 19, 2016 11:38 AM
limited01
Ford Truck Parts for Sale
May 12, 2010 06:23 AM
jpb222
Dec 14, 2009 12:21 PM
