i6 300 specs
Old Nov 6, 2003 | 11:20 AM
Dick Ginther's Avatar
Dick Ginther
i6 300 specs
Hi,
I using Dyno2000 to evaluate changes to my 1979 Ford F150
I6 300. In particular, I would like to know things like the stock
compression ratio and the stock cam duration/lift.
If anyone has done this before or has this information that
would great!
Thanks.
Old Nov 7, 2003 | 11:21 PM
NM5K's Avatar
NM5K
They varied to the year. Some were 8.4, some early ones 8.0, some 8.8 . It's between 8.4 and 8.8 anyway... Hopefully someone else will chime in with better info.
The only stock cam info I have shows .2490 for both intake and exhaust lobes. MK
Old Nov 8, 2003 | 02:41 PM
Vampiro's Avatar
Vampiro
bore 4.00
stroke 3.980
compression 8.5
induction flow 200cfm
intake valves 1.781
exhaust 1.560
thats what i came up with and when done rite the dyno says 140hp and and 240 lbs torque which is about right for the 300
Old Nov 11, 2003 | 06:58 AM
dj8667's Avatar
dj8667
can you tell me how much hp and torque i am getting out of my 300.
4.03 bore
3.98 stroke
500 cfm carb
.015 head shave
204/216 Adv. Dur. Int./Exh.
.458 intake lift
.487 exhaust lift
and stock valves
Thanks, i would appreciate it
D.J
Old Nov 13, 2003 | 09:01 AM
Dick Ginther
Hi,
I get 125hp@3000rpm with 234ft/lb@2000rpm for the stock
i6 300. With your new specs, I get 160hp@3500 and 260ft/lb
@3000rpm, but there is not enough cam information.
I calculated that the new compression ratio would be 8.7:1. In
order to get better cam curves, I need to also know the lobe
center of your cam. That way, I can calculate other parameters.
Does anyone know the specific cam details on a stock i6 300? In
particular, the intake duration, exhaust duration and lobe center?
Thanks.
Old Nov 13, 2003 | 09:06 PM
darkman's Avatar
darkman
Add in the 1.75 ratio rockers
I think the jury is still out but would one of you figure the difference between a stock 85 300 and one with the addition of the 1.75 ratio rocker arms.
Old Nov 14, 2003 | 09:08 AM
Dick Ginther
Sure, just give me the ratio of the stock 300 and the answer is
just a couple of mouse clicks away....
Old Nov 14, 2003 | 06:47 PM
darkman's Avatar
darkman
What ratio do you use on the stockers or do you just use cam lift?
Old Nov 14, 2003 | 08:10 PM
broncr's Avatar
broncr
Welcome to FTE, (DG)
I believe the stock rocker ratio is 1.6. ('been looking into changing it - and thats what other posts are saying).
If it's just a few mouseclicks, would you mind running my numbers? I have a stock cam and the rest of my engine numbers are in my sig., below.
Thanks, Broncr
Old Nov 19, 2003 | 10:34 AM
Dick Ginther
Just adding the 1.75 lift rockers by themselves did very little. It
changed the valve lift from 0.249" to 0.272" and added 2HP.
Old Nov 20, 2003 | 08:40 AM
broncr's Avatar
broncr
"If it's just a few mouseclicks, would you mind running my numbers? I have a stock cam and the rest of my engine numbers are in my sig., below. Thanks, Broncr [/B][/QUOTE]
Old Nov 21, 2003 | 08:05 AM
Dick Ginther
Hi,
A 309 with 10.5:1 compression, 390cfm carburation and
headers gets 167hp@3500 and 312ft/lb@2000 according
to my dyno entries.
Old Nov 22, 2003 | 09:43 AM
broncr's Avatar
broncr
thanks
Old Nov 22, 2003 | 05:21 PM
darkman's Avatar
darkman
Something doesn't seem right with those numbers. Is .249 the lift of a stock cam at the lifter? If so then the vavle lift would be .398 and using the 1.75:1 rockers would yield .436 at the valve or a gain of .038. That is a good increase in lift and I would expect a lot more than two HP. can you check it again please.
Old Nov 22, 2003 | 09:25 PM
broncr's Avatar
broncr
I'm with ya Darkman. Actual valve opening is close to .400 - stock,
and my SOTP meter says I've got around 200 horsies, at least.
I imagine there's not a program alotment for port, polish, & mate, and since flow = HP on the 300, there's room for wiggle. A quality engine ballance does wonders too- less horsetheivin'...
My thanks for running the numbers anyway. I'll probably never have it dyno'd.
Broncr
