Transmission fluid boiled
Old Feb 17, 2022 | 10:38 AM
Wilbbill88's Avatar
Wilbbill88
I bought a 1993 f250 idi. I towed it back to my house using a dolly. I put the transfer case in “n” but when I got to my house the fluid sounded like it was boiling and dripping to the ground. What are the chances that I did not mess up the transmission? Not wanting to buy a new/use/remand transmission. I have already rebuilt the transfer case. Thanks in advance.
Old Feb 17, 2022 | 10:50 AM
Farmer Rock's Avatar
Farmer Rock
Trailering
I'm no auto transmission expert, but if the transfer case and transmission were both in neutral there shouldn't have been a problem caused by towing it.
I'm assuming you bought this truck non running?
Rock
Old Feb 17, 2022 | 11:02 AM
Wilbbill88's Avatar
Wilbbill88
Yes I bought the truck non running. I had both in “N” but when I stopped it was sounding like a boil and dripping to the ground. I only worry it slipped into gear on the transfer case.
Old Feb 17, 2022 | 12:20 PM
Olds64's Avatar
Olds64
Being a 93 it has the E4OD transmission. You should have removed the driveshafts to flat or dolly tow it. Modern automatics have a front pump, the engine needs to be spinning to turn the transmission pump to keep fluid running through it. I suggest to only ever flat/dolly tow a RWD/4WD vehicle with an automatic on a short drive in town at a max of 40 mph or so. If you need to tow it farther or faster just remove the driveshafts and you'll be fine.
Old Feb 18, 2022 | 07:19 AM
Dieselamour's Avatar
Dieselamour
I believe you should not have any issues. The manual should tell you.Does the transfercase have a manual lever you placed in "N" or an electronic/vacuum operated actuator?
If a manual lever, the only thing I could think went wrong was linkage out of adjustment or a lift where the lever is out of sync with the markings for neutral.
[Was anything dripping on the ground?]
Pastor Scott K
Aug 17, 2020 08:32 PM
2002Ex
Jun 27, 2020 09:55 PM
dant
Nov 16, 2019 11:28 AM
texrdnec
May 10, 2017 06:40 PM
stepside64
Offroad & 4x4
Mar 25, 2004 08:57 PM
