Driven Diesel E-Fuel
Old Feb 17, 2022 | 04:57 PM
Ford Firefighter's Avatar
Ford Firefighter
Maybe so, I don’t think we talked filters, but I’ll listen lol
Old Feb 17, 2022 | 05:02 PM
Hit Man X's Avatar
Hit Man X
Reread. So okay sounds like filters were reversed?
Maybe damaged pump. Sure it is a real Bosch? Is that selector still bypassed?
Old Feb 17, 2022 | 05:09 PM
Ford Firefighter
Yeah I guess reversed, i had the water separator pre pump and it seemed to cause cavitation in the pump…
And the pump looks like a Bosch to me but I suppose I don’t know for sure. Came with the warranty fill out page
Yeah I have the selector bypassed currently, there’s a guy north of San Antonio that puts together bronco tank kits that I want to pickup and get rid of the selector for good
Old Feb 17, 2022 | 05:12 PM
Hit Man X's Avatar
Hit Man X
Did you actually watch fuel pressure fall as you got into throttle?
Old Feb 17, 2022 | 05:17 PM
Ford Firefighter
No I didn’t watch it, it felt like it but other times after running it for a short bit I opened the hood and watched the gauge drop in pressure down to 20 usually it would stay at 20 other times it would completely die
Old Feb 17, 2022 | 05:18 PM
Ford Firefighter
The gauge is under the hood, I don’t have an in cab gauge… yet!
Old Feb 17, 2022 | 05:24 PM
Hit Man X's Avatar
Hit Man X
Long shot, might be unrelated issue that is the issue.
Anyway to check vitals while under load? Other guys know all about that stuff. Tools. Programs. Etc. Above my GS rating.
Old Feb 17, 2022 | 05:30 PM
Ford Firefighter
Been kinda getting to that point, I don’t currently have a way to read anything but I know I need to have a something so maybe this is the time!
what do/would you use?
Old Feb 17, 2022 | 05:35 PM
Hit Man X's Avatar
Hit Man X
I think most guys use Forescan?
Make sure your ride is OBD2 compliant. 94.5 and E95 were simply ready.Apparently a chip like TS or Hydra makes the early compliant without a reflash.
I really am of no use trying to datalog and such. I did get my old Edge Insight to work on my 96 though!
Old Feb 17, 2022 | 05:42 PM
Ford Firefighter
Okay thanks!
Ive actually been trying to decide between a Edge or or a set of gauges, I like all the stuff you can do with the Edge
Old Feb 17, 2022 | 06:05 PM
Hit Man X's Avatar
Hit Man X
Just note my Edge is old black and white model. Not a CS/2/whatever stuff. Works fine for my needs, but yours could vary far more than mine.
I just look at boost, EGT, HPOP, and oil temp when I care. Usually it is not even in my truck.
Old Feb 17, 2022 | 06:14 PM
Ford Firefighter
10-4 Thanks!
Old Feb 19, 2022 | 10:10 PM
  #28
idshred's Avatar
idshred
It’s normal to have the water separator pre pump and the finer filter post pump.
so what exactly did you change to make it run ‘normal’??
is this the kit you bought?
https://www.strictlydiesel.com/produ...ic-fuel-system
Old Feb 19, 2022 | 11:01 PM
  #29
Ford Firefighter
Yep that’s the kit, I moved the water separator to the post pump position and the other one to the pre pump position and it then ran excellently
Old Feb 21, 2022 | 07:15 AM
  #30
Edgethis's Avatar
Edgethis
Thats odd. The micron filtration level of thr filters can cause issues if you have too restricted of a pre pump filter on there. I would think the water seperstor wouldn't be a very low micron, usually like 100.
If it runs now then thats what matters. Just keep an eye on you separator for the first few weeks.
