1/2" or 1" coil spacer lift - anything else needed?
I'd like to lift the front of my truck up just a touch, especially with the weight of the OEM winch up front now and the lack of uptravel from the factory. I found these guys that make 1/2" and 1" coil spacers. My question is if anybody has installed these and found any alignment problems that require an adjustable track bar. Or are any other parts like longer shocks, extended brake lines, or anything else required? I'm pretty competent mechanically, but don't know what the limitations of lifting the front of these trucks without problems are.
https://kryptoniteproducts.com/colle...-kit-2005-2021
The following users liked this post:
Good info. Thank you. It seems like steering stabilizer upgrades are common on these trucks. That might be something I do regardless if I lift the front or not.
the bolts at the link have no locktite...the oem ones your going to pull out do.
so pick your poison , blue, orange or red. orange and blue dont require heat to remove.
if you dont use locktite, you may hear creeking on excel in a few hundred miles.
Thanks for the heads up. I have blue and red in my garage. Red isn't as permanent as some people think. I've never had to heat something up to get loose yet.
I installed the Ready-lift 1" on my 2019 and had no issues (alignment, bump steer, lines, etc).
I have a 1.5” PMF spacer on my truck with nothing else. My front axle is ever so slightly offset to the driver side but so little that I think a track bar relocation bracket would over correct it. I elected to do the SPC caster shims at the same time and have no drivability issues. I also elected to go with Bilstein 5100 shocks but the stock shocks would have worked fine with no extension brackets. I say go for it.
I purposely ordered a truck with the lightest springs available on a F350. I'd prefer not to make the ride an more harsh than it already is. As long as it can handle my trailer fine, then there's no need for a higher spring rate. I'll know that for sure this spring, but I can't imagine there will be any problem. My 2015 F350 also had the lightest springs available on it.
I wish Carli made their coils in less than a 2.5" lift. I've ridden in a truck with these and some properly valved shocks and the improvement in ride over OEM is significant. I don't know what the rate is on the Carli coils versus OEM, but they sure felt a lot softer, yet still able to handle the trailer just fine.
