2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Windshield Wipers Quit
Old Feb 15, 2022 | 07:20 AM
Ifarm's Avatar
Ifarm
2017 Expedition EL Limited front windshield wipers quit on full wipe. Checked the fuse and even tried switching it with a different one. Anyone have any advice? I appreciate it
Old Feb 15, 2022 | 08:06 AM
BassFantasizer's Avatar
BassFantasizer
It sounds like it's in the motor or wiring harness. Can you test to see if there's power to the motor?
Old Feb 16, 2022 | 12:50 PM
Ifarm's Avatar
Ifarm
Turns out it’s the wiper motor.
Thanks!
Old Feb 16, 2022 | 04:00 PM
pdqford's Avatar
pdqford
So, how did you diagnose it to the wiper motor?
Old Feb 16, 2022 | 06:35 PM
Ifarm's Avatar
Ifarm
I took the wipers off, the plastics off(which are next to impossible to break here in Michigan) and exposed the motor and regulator. I turned the key on, put the wipers on constant slow and tapped on the motor with a small hammer and it moved again but is extremely noisy. $150 from Ford, so I’m shopping right now.
Old Feb 17, 2022 | 06:45 AM
BassFantasizer
Glad you found it. It's usually a good thing that it's the item on the end of the wire than the wiring harness. Tracing through a wiring harness can be a pain...
Rockauto has the Motorcraft pump for $105.
svanstrom
Sep 14, 2017 10:17 AM
Scott B IA
Aug 6, 2015 08:22 PM
AbandonedBronco
1978 - 1996 Big Bronco
Oct 12, 2013 06:03 PM
JohnnyLaw
Electrical Systems/Wiring
Aug 3, 2003 09:50 AM
