Please help! (Crank no start)
Old Feb 15, 2022 | 07:19 PM
Jakurka99's Avatar
Jakurka99
4wd Low
UPDATE- After going down the rabbit hole, went and got alternator tested. All is good but after throwing it on noticed the ground nut was ****ty. Looking at codes the truck fired with a misfire 2 on both banks. Wiggled the injector harness and pushed the wires going into the connectors in further and BOOM! fired right up. Gonna look for a injector harness. Thank you guys for y'alls help.
Old Feb 15, 2022 | 07:30 PM
Jakurka99's Avatar
Jakurka99
4wd Low
also Vacuum pump is acting normal again.
Old Feb 15, 2022 | 08:16 PM
diesel_dan's Avatar
diesel_dan
Well THAT was a ride...! Stick around - you can very well help others, like yourself, that happen upon this forum...
Thanks for closing out your thread, and may many a happy mile be before you...
Old Feb 15, 2022 | 10:01 PM
pnw_at's Avatar
pnw_at
Are you referring to the injector harness connectors that plug into the FICM, or at the injectors themselves?
Old Feb 15, 2022 | 10:20 PM
Jakurka99's Avatar
Jakurka99
4wd Low
Pushed the wires into the connectors at the injectors, this isnt what caused the truck to die in the first place. This was after everything was put back together and became a new hidden problem. Also the plug wasnt all the way in on the ficim but pushing that in didnt change anything.
DAVO1151
Jul 31, 2020 10:18 AM
Matthew Todice
Oct 1, 2019 04:17 PM
KYpipeliner1511
Nov 2, 2017 09:42 PM
usmarine1979
Jun 2, 2016 11:27 AM
cheapstein
Oct 16, 2013 10:47 AM
